[AG-TECH] compat 2.4
George Estes
gestes at NCSA.UIUC.EDU
Thu Feb 8 14:10:36 CST 2007
When I started the client for the first time a message came up saying the anonymous cert had expired and I should request a new certificate. Clicking ok brings up the new certificate request wizard. After going through the request wizard nothing happens. Rerunning the client and cancelling out of the request wizard brings up the client interface. The anonymous cert appears to be valid. But in Certificate Request there are maybe a dozen new certificate requests that under status say no private key found. I imported my identity cert and everything works fine.
George
At 12:47 PM 2/8/2007 -0600, Thomas D. Uram wrote:
>What's the problem with the anonymous cert?
>On 2/8/07 12:09 PM, George Estes wrote:
>>Thanks Mike. That was the problem. It had not been a problem in earlier versions of Fedora. Although there is still an issue with the anonymous cert in the fc6 version of compat 2.4.
>>Thanks again,
>>George
>>At 11:05 AM 2/8/2007 -0500, Mike Weaver wrote:
>>>More than likely, this is due to the default state of SELinux. You can
>>>disable SELinux altogether by setting the line
>>>SELINUX=disabled
>>>in your /etc/sysconfig/selinux file and rebooting.
>>>Mike
>>>-----Original Message-----
>>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>>Behalf Of George Estes
>>>Sent: Wednesday, February 07, 2007 22:18
>>>To: ag-tech at mcs.anl.gov
>>>Subject: [AG-TECH] compat 2.4
>>>I've just built a Fedora Core 6 machine and installed 3.0 and compat
>>>2.4. The 3.0 version runs fine but when I run the AGServiceManager24 I
>>>get this error?
>>>George
>>>Traceback (most recent call last):
>>> File "/usr/bin/AGServiceManager24", line 25, in ?
>>> from AccessGrid.hosting import SecureServer, InsecureServer
>>> File
>>>"/usr/lib/python2.4/site-packages/AccessGrid2/AccessGrid/hosting/__init_
>>>_.py", line 120, in ?
>>> SetHostingImpl(__hostingImpl)
>>> File
>>>_.py", line 62, in SetHostingImpl
>>> s = __import__(nis, globals(), locals(), ["SecureServer",
>>> File
>>>"/usr/lib/python2.4/site-packages/AccessGrid2/AccessGrid/hosting/SOAPpy/
>>>Server.py", line 20, in ?
>>> from SOAPpy.GSIServer import ThreadingGSISOAPServer, GSIConfig
>>> File "/usr/lib/python2.4/site-packages/SOAPpy/GSIServer.py", line 74,
>>>in ?
>>> from pyGlobus.io import GSITCPSocketServer,
>>>ThreadingGSITCPSocketServer
>>> File "/usr/lib/python2.4/site-packages/pyGlobus/io.py", line 14, in ?
>>> import ioc
>>>ImportError: /usr/lib/globus/lib/libcrypto_gcc32pthr.so.0: cannot
>>>restore segment prot after reloc: Permission denied
