[AG-TECH] AG3.1: Blocked VenueClient when connecting to Server
    Michael Braitmaier
    braitmaier at hlrs.de
    Wed Aug 22 07:36:42 CDT 2007
After testing a connect to the AG3 Beta Lobby and being able to connect,
this implies that the problem I described may be based on my local
configuration on my machines.
So I will go back for further testing, however any idea would be welcomed.
Michael
Michael Braitmaier schrieb:
> I am recently trying to connect with a venueclient to a venueserver on
> the same machine(WinXP, no MC). However both client and server are
> blocking once they reached a
> specfific part in the process. From the log-files, I can't make up
> anything unusual except the fact that I disabled starting of the
> Beacon service (see #Bug 1701)
> I attached the last parts of my logs from the server and the client as
> far as they created output befor entering blocking state.
> After that I can only kill the venueclient process through the task
> manager and then normally exit the server with ALT-C.
> I encountered the same behaviour on a second machine (WinXP, MC) both
> times using the latest CVS code of AG3.1 beta-1.
> There is no further log-output being created from that point on until
> I kill the venueclient.
> I hope someone can give me a hint.
> Michael
> VenueServer:
> 08/22/07 11:16:39 4052 VenueServer     venue.py:488 INFO  User None
> authorized for action NegotiateCapabilities
> 08/22/07 11:16:39 4052 VenueServer     venue.py:839 DEBUG negotiate
> capabilities
> 08/22/07 11:16:39 4052 VenueServer     venue.py:848 DEBUG Capability
> to be processed: producer, Beacon, 1, ANY, 0, 1, None, None
> to be processed: consumer, Beacon, 1, ANY, 0, 1, None, None
> 08/22/07 11:16:39 4052 VenueServer     venue.py:893 DEBUG Stream
> doesn't exist create new one!
> 08/22/07 11:16:39 4052 VenueServer     venue.py:898 DEBUG Stream type:
> Beacon!
> 08/22/07 11:16:39 4052 VenueServer     venue.py:909 DEBUG  Caps:
> 08/22/07 11:16:39 4052 VenueServer     venue.py:915 DEBUG Stream
> prefers multicast!
> 08/22/07 11:16:39 4052 VenueServer     venue.py:918 DEBUG Stream
> address: 224.2.180.121 : 59880
> 08/22/07 11:16:39 4052 VenueServer     venue.py:928 DEBUG added user
> as producer of non-existent stream
> 08/22/07 11:16:39 4052 VenueServer     venue.py:2405 DEBUG * * * Added
> stream producer 8d3a080a0e9427af990bb4fb9d26cfe6
> 08/22/07 11:16:39 4052 VenueServer     venue.py:933 DEBUG sending
> AddStream event; stream=StreamDescription: {'description': None,
> 'encryptionKey': None, 'uri': None, 'encryptionFlag': 0, 'capability':
> [producer, Beacon, 1, ANY, 0, 1, None, None, consumer, Beacon, 1, ANY,
> 0, 1, None, None], 'static': 0, 'location': multicast 224.2.180.121
> 59880 127, 'id': '8d3a080a0e9427af99190577042d1dbb',
> 'networkLocations': [multicast 224.2.180.121 59880 127], 'name':
> 'Venue Server Lobby'}
> VenueClient:
> 08/22/07 11:16:37 3916 VenueClient     venueclient.py:1210 DEBUG
> EnterVenue; url=https://141.58.8.10:8000/Venues/default type=<type 'str'>
> 08/22/07 11:16:37 3916 NodeService     agnodeservice.py:664 INFO
> NodeService.GetCapabilities
> 08/22/07 11:16:37 3916 NodeService     agnodeservice.py:258 INFO
> NodeService.GetServices
> 08/22/07 11:16:37 2736 ServiceManager     agservicemanager.py:220
> INFO  AGServiceManager.GetServices
> 08/22/07 11:16:37 3916 VenueClient     venueclient.py:1222 DEBUG
> Capability on VenueEnter: producer, Beacon, 1, ANY, 0, 1, None, None
> Capability on VenueEnter: consumer, Beacon, 1, ANY, 0, 1, None, None
> 08/22/07 11:16:37 3916 VenueClient     venueclient.py:1247 DEBUG
> calling __EnterVenue
> 08/22/07 11:16:37 3916 VenueClient     venueclient.py:999 DEBUG
> EnterVenue: Invoke Venue.Enter
> 08/22/07 11:16:39 3916 VenueClient     venueclient.py:1001 DEBUG after
> Venue.Enter
> 08/22/07 11:16:39 3916 VenueClient     venueclient.py:1003 DEBUG
> EnterVenue: Invoke Venue.getstate
> 08/22/07 11:16:39 3916 VenueClient     venueclient.py:1005 DEBUG
> EnterVenue: done Venue.getstate
> 08/22/07 11:16:39 3916 VenueClient     venueclient.py:1028 DEBUG
> Setting isInVenue flag.
> 08/22/07 11:16:39 3916 VenueClient     venueclient.py:1249 DEBUG after
> __EnterVenue
> 08/22/07 11:16:39 3024 VenueClient     venueclient.py:589 DEBUG
> Calling Heartbeat, time now: 1187774199
> 08/22/07 11:16:39 3916 VenueClient     venueclientui.py:3185 DEBUG
> EnterVenue: Enter venue with url: https://141.58.8.10:8000/Venues/default
> 08/22/07 11:16:40 3916 VenueClient     venueclientui.py:3252 DEBUG
> Load Venue data store data
Dipl.-Inf. Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Website: http://www.hlrs.de/people/braitmaier/
