[AG-TECH] AG3.0.2 on MacOSX
John Toenjes UIUC
jtoenjes at uiuc.edu
Mon Apr 2 10:05:29 CDT 2007
Nic,
Copy the attached file to
/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/
and you should be good to go. You will find a file there called
compileall.pyo, but this one with the .py extension needs to be there for
the installer to work. I had the same problem myself.
Good luck.
John
John Toenjes
Assistant Professor and Music Director
University of Illinois Urbana-Champaign Department of Dance
907 1/2 W. Nevada St.
Urbana, IL 61801
(217) 265-0359
President, International Guild of Musicians in Dance
http://www.dancemusician.org
> From: Nicolas Bertrand <nsb at ceh.ac.uk>
> Date: Mon, 2 Apr 2007 13:19:08 +0100
> To: <ag-tech at mcs.anl.gov>
> Subject: [AG-TECH] AG3.0.2 on MacOSX
> Hi,
> I am experiencing problems installing the required components for
> running Access Grid 3.0.2 on Mac OSX.
> The python components listed on http://www-unix.mcs.anl.gov/fl/
> research/accessgrid/software/releases/3.0.2/macosx.html#tiger fail to
> install.
> Platform: Intel Mac, 10.4.9
> Any ideas?
> Thanks,
> Nic
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070402/6d8ba945/attachment.obj>
