[AG-TECH] AG 2.4 and 3.0 servers
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Thu Sep 28 10:22:03 CDT 2006
In Psi, once you are connected (Online) select "Service Discovery" from the "Psi" menu. There should then be an "AG Text Chats" list containing all the current chats. If your client is connecting then your venue will be listed here.
As Tom states, there might be something in the VenueClient.log file to suggest what is going wrong.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Jeremy Mann
> Sent: 28 September 2006 15:36
> To: Andrew.Rowley at manchester.ac.uk
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] AG 2.4 and 3.0 servers
> How do I browse the group chats? I have PSI installed and I'm
> connected to jabber.mcs.anl.gov. I go to Join Group Chat and it asks
> me for host, room and nickname. There is no way, that I can tell, to
> browse the group chats.
> On 9/28/06, Andrew A Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> > Hi,
> > This is odd - this suggests that you cannot connect to the jabber server
> from your client (I am fairly sure this is all done on the client side
> now). It is worth logging on to the ANL server with another jabber client
> and seeing if you can see any rooms for your server in the service
> discovery. Room names are the venue name with the spaces removed with
> your server hostname appended in brackets (take a look and you should see
> what I mean).
> > Andrew :)
> > RSS Group,
> > Kilburn Building,
> > Oxford Road,
> > Manchester,
> > M13 9PL,
> > UK
> > > From: Jeremy Mann [mailto:jeremymann at gmail.com]
> > > Sent: 27 September 2006 20:00
> > > To: Andrew Rowley
> > > On 9/27/06, Andrew Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> > > > Hi,
> > > > If you copied your old server config, you will need to change the
> > > textPort to
> > > > 5223 (it is probably 8002 or something like that just now). You can
> run
> > > your
> > > > own Jabber server, but anl host one that seems stable (plus there
> are
> > > > loads out
> > > > there) at jabber.mcs.anl.gov. This should be set by default as your
> > > textHost
> > > > in your VenueServer.cfg file.
> > > Thanks Andrew. I have changed textPort to 5223 and left the address to
> > > the ANL jabber server. However, when I enter my Lobby and type
> > > something it says:
> > > You have to be connected to a venue to send a text message
> > > Jeremy
> Jeremy
