[AG-TECH] port ranges for unicast briges
Thomas D. Uram
turam at mcs.anl.gov
Wed Sep 13 09:42:23 CDT 2006
Hi Monika:
The AG2 Argonne bridge info is:
host: milton.mcs.anl.gov
ports: 50000-50250
The AG3 Argonne bridge information is:
ports: 52000-54000
Note that the AG3 bridge information can be viewed from within
the VenueClient. If you select Preferences, then Network,
you'll see a list of bridges, complete with the location, hostname,
port range, and some other info. This info is provided as an aid
in configuring firewalls; if this doesn't suffice for anyone, I'd
be curious to know.
Tom
On 9/13/06 9:04 AM, monika.k.rabarison at ccaix.jsums.edu wrote:
> Hello,
> This might be a question just for ANL and NCSA.I send it to
> the list in case someone else needs the response too, to
> help deal with firewall issues.
> Could you let know the range of UDP ports you are using for
> the NCSA and ANL bridge servers, for 2.4 and 3.0.2?
> Thank you in advance,
> Monika
