[AG-TECH] Unable to connect or load bridge information.
Darren Condon
D.Condon at latrobe.edu.au
Wed Sep 6 18:12:42 CDT 2006
I've never had the problem where the client hangs "loading bridges".
Here at La Trobe Uni and at Wollongong we just don't see any bridges at
all.
This has remained the same through 3.0, 3.01 and 3.02. Relevant section
of the venueclient.log file is
09/07/06 08:51:07 2224 VenueClient venueclient.py:242 DEBUG get
bridges from registry
09/07/06 08:51:30 2224 VenueClient venueclient.py:253 ERROR
__LoadBridges: Can not connect to bridge registry
http://www.accessgrid.org/registry/peers.txt
Traceback (most recent call last):
File
"C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\VenueClient.py",
line 248, in __LoadBridges
bridgeList = self.registryClient.LookupBridge(10)
File
"C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Registry\RegistryC
lient.py", line 108, in LookupBridge
self._connectToRegistry()
File
lient.py", line 33, in _connectToRegistry
self.registryPeers = self._readPeerList(url=self.url)
File
lient.py", line 163, in _readPeerList
f = opener.open(url)
File "C:\Python23\lib\urllib.py", line 181, in open
return getattr(self, name)(url)
File "C:\Python23\lib\urllib.py", line 297, in open_http
h.endheaders()
File "C:\Python23\lib\httplib.py", line 715, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 600, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 567, in send
self.connect()
File "C:\Python23\lib\httplib.py", line 551, in connect
raise socket.error, msg
IOError: [Errno socket error] (10060, 'Operation timed out')
09/07/06 08:51:30 2224 VenueClient venueclient.py:256 DEBUG set
bridges in prefs
09/07/06 08:51:30 2224 VenueClient venueclient.py:265 DEBUG connect
to bridge
09/07/06 08:51:30 2224 VenueClient venueclient.py:269 DEBUG exiting
loadbridges
09/07/06 08:51:30 2224 NodeService agnodeservice.py:289 INFO
NodeService.SetServiceEnabledByMediaType
09/07/06 08:51:30 2224 NodeService agnodeservice.py:257 INFO
NodeService.GetServices
Tom, should I file this as a bug? I've never been quite sure since some
of my problems in the past have been caused by the way our network
domain is set up.
Cheers,
Darren Condon
Department of Mathematics and Statistics
La Trobe University, Victoria 3086
Australia.
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Thomas D. Uram
Sent: Thursday, 7 September 2006 5:52 AM
To: gkhanna at dartmouth.edu
Cc: Jimmy Miklavcic; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Unable to connect or load bridge information.
This problem should now be resolved. I'm monitoring it in case the
problem recurs. As always, thanks for reporting it.
On a related note, plans are underway to avoid this kind of problem
completely in the future.
Tom
On 9/6/06 2:32 PM, gurcharan khanna wrote:
> Hi,
> I just installed AG 3.0.2 on a new XP machine and when i try to start
> the venue client, it hangs at the first popup box, saying "loading
bridges".
> is that related to jimmy's problem below?
> -gurcharan
> Jimmy Miklavcic wrote:
>> At startup of AGTK-3.0.2 in Windows XP, I am uanble to load and
>> connect to the bridges. It worked last friday. Any ideas?
>> Right now in the Bridges drop down menu, there is nothing listed.
>> Jimmy
>> Jimmy Miklavcic
>> Multimedia Specialist
>> jimmy.miklavcic at utah.edu
>> UNIVERSITY OF UTAH
>> CTR FOR HIGH PERFORM COMPUTING
>> 155 SOUTH 1452 EAST RM 405
>> SALT LAKE CITY, UT 84112-0190
>> Office: 801.585.9335
>> Fax: 801.585.5366
>> http://www.anotherlanguage.org
