[AG-TECH] RE: [AG-DEV] Parallelize some of the functions of the Start-Up for the Venue Client
Jason Bell
j.bell at cqu.edu.au
Tue Sep 5 09:08:46 CDT 2006
Sorry, this email was meant to be sent to the AG-Dev list.
Apologies,
Jason.
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Jason Bell
Sent: Tuesday, 5 September 2006 11:44 PM
To: ag-tech
Subject: [AG-TECH] RE: [AG-DEV] Parallelize some of the functions of the
G'day all
I think I should mention that while testing my own AG 3 Bridge, I was
one of those "baddies" as well.
What this highlighted is how easily it would be for someone to "simply"
create a "baddy" bridge without realising it.
The purpose for my testing was to add additional documentation on my
install guide on how to configure a unicast bridge and Venue Server for
AG 3. I am very reluctant to release any documentation that shows how
to configure a Bridge as it may inadvertently create more "baddies",
thus causing the AG3 VenueClient to be almost unusable due to the long
start-up time.
Anyway, some constructive comments in my opinion on ways we could
possibly improve this would be:
* Having the Load_Bridge() run/execute as a separate
process/thread in which would operate independent of the starting up of
the VenueClient itself. The benefits of this could be:
- Running as a separate process shouldn't affect the
performance of starting the Venue Client, etc.
- Also, you could re-run this function separately which
would continually update the latest list of bridges. As I have found
recently that the list of bridges is only as accurate to when the
VenueClient was first started.
* Another idea, based upon Rhys's suggestion is that if something
doesn't respond after a short delay (rather than a time out), then don't
list the bridge. This would then only list bridges that would be
acceptable to use. The downside of this is that the list of bridges
"WILL" grow and still cause some delay, though not as long.
* Based upon Andrew's suggestion, having the ability for a Bridge
to Register to different registries, would allow (I think) the bridges
to be assigned to various regions. That way, a registry could list
"Good" unicast bridges for the various regions, cutting down the number
of bridges tested and loaded.
I honestly think that the possible solution to this problem is most
likely a combination of some of the suggestions above, and possibly some
other ideas.
Anyway, I think this is a very important issue and hopefully we may be
able to come up with some real "fixes" to the problem.
Cheers,
Jason.
From: Christoph Willing [mailto:willing at vislab.uq.edu.au]
Sent: Tuesday, 5 September 2006 4:54 PM
To: Rhys Hawkins
Cc: Jason Bell; ag-dev at mcs.anl.gov
Subject: Re: [AG-DEV] Parallelize some of the functions of the Start-Up
On 04/09/2006, at 3:45 PM, Rhys Hawkins wrote:
[snip]
> I've commented out line 125 in AccessGrid/Registry/
> RegistryClient.py, ie:
> #self.bridges = self._sortBridges(maxToReturn)
> I don't know whether this will help your colleague or not. It
> certainly
> makes things quicker for me. If you're just testing a local bridge
> then
> you could just stick you local bridge description in the beginning
> of the
> list to fake the sort. Although this is just hacking for testing
> purposes
> and doesn't solve the actual problem.
I was doing something similar (VenueClient.py at line 199, comment
out self.__LoadBridges()), which is fine if you don't need bridges.
Today I needed to connect to a site whose only visibility was through
a bridge they were running, so I had to reinstate them, but block the
baddies. I now have a list of offending bridges inserted at the
beginning of the PingBridgeService() definition (line 63) in
RegistryClient.py. These sites are skipped as follows:
def PingBridgeService(self, bridgeProxy):
banned = ['some.site', 'another.site']
for b in banned:
if bridgeProxy._ServerProxy__host.startswith(b):
return -1
self.log.info('PingBridgeService: trying %s' %
bridgeProxy._ServerProxy__host)
etc. as before
The extra logging line shows progress through the bridges a bit
better and identifies new baddies.
Of course its cumbersome to edit RegistryClient.py everytime a new
baddy is detected (there have been a few recently), but I generally
have a fast start up now, as well as having access to "good" bridges.
Maybe a separate configuration file containing the baddies would be
better; the VenueClient could consult it at startup before processing
the bridge list.
chris
Christoph Willing +61 7 3365 8350
QCiF/QPSF Access Grid Manager
University of Queensland
