[AG-TECH] Using Access Grid with Ethernet Bridged OpenVPN
Many Ayromlou
mayromlo at ryerson.ca
Mon Oct 30 15:56:44 CST 2006
Hi Doug,
A while back I tried OpenVPN (mac client @ home behind NAT/Router---
>linux server on open network) and although other stuff worked, I
could not get AG going (I was not using bridged mode though.....I was
using the other mode.....don't remember right now).
I have since tried to run it with an L2TP type VPN (Mac notebook
running osx behind NAT/Router --> Mac OSX Server on open network) and
AG3 works quite well. I've been able to get somewhere near 14-16
videos smoking my 6Mb dsl link. I've also tried this from behind a
firewall at work (mac notebook behind a really strict firewall
blocking ports 1024+ UDP/TCP ---> same mac OSX server on open
network) and AG3 works fine.
So to answer your question OpenVPN did not work for me and I admit it
was not the same situation you're describing. L2TP worked fine behind
NAT and also behind a pretty strict firewall.
TTYL
Many
On 30-Oct-06, at 1:35 PM, Doug Baggett wrote:
> Has anybody tried using Access Grid using bridged Ethernet and
> OpenVPN?
> (www.openvpn.net)
> OpenVPN supports TCP instead of UDP, and I have users behind
> Firewalls that
> restrict outbound UDP and I have a server that I could use as the
> endpoint
> that sits
> I know there would be a performance hit using TCP, but on a high
> performance
> network it would be interesting to know if anybody has given it a try.
> -Doug B
> OCI/NSF
