[AG-TECH] Error in making a rpm of accessgrid-vic.
douglask at itee.uq.edu.au
Wed Oct 18 16:46:09 CDT 2006
Quoting lgq <liugq at vrlab.buaa.edu.cn>:
> Following are the error:
> [root at lgq SPECS]# rpmbuild -ba AccessGrid-vic.spec
> error: Failed build dependencies:
> gtk-doc is needed by AccessGrid-vic-2.8ucl1.1.3-3.20051206darcs.i386
> How should I install gtk-doc?
The gtk-doc RPM comes with the Fedora media, or alternatively you can install it
using yum:
yum install gtk-doc
you probably want to be be building the newer
AccessGrid-vic-2.8ucl1.1.3-4.20060619cvs SRPM rather than the one you were
building. It is also found in here:
http://www.vislab.uq.edu.au/accessgrid3/fedora/5/SRPMS/
Doug
