[AG-TECH] query re: delay
    Alan Sondheim
    sondheim at panix.com
    Mon Oct  2 04:04:08 CDT 2006
You're right about the breakup. It's less when we go to the Test Room
since I'm using a smaller bandwidth. I'm on a PIG/DSL, so there are
uploading issues. The odd thing is the length of the delay, which was
really fantastic. I'll check on the Reception of course and thanks (and
thanks to everyone who replied).
- Alan
On Mon, 2 Oct 2006, Andrew A Rowley wrote:
> Hi,
> In RAT, you can go to "Options..." then select "Reception" from the top menu.  From here you can limit the playout delay to 1 second (if I am reading it correctly).
> Playout delay in RAT is adaptive - my understanding of this is that if there are lots of packets arriving late, it will increase the delay until there is enough that most packets arrive within the time of the playout delay.  I think that VIC does this too, but no so aggressively, hence the difference between audio and video delays.  I am guessing that you see lots of breaking up of the video which would show that it is having to throw away lots of late packets.
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
>> -----Original Message-----
>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>> Behalf Of Alan Sondheim
>> Sent: 30 September 2006 01:12
>> To: 'ag-tech'
>> Subject: [AG-TECH] query re: delay
>> I've been working on a PIG in Brooklyn, New York, through DSL, connected
>> through Argonne to an AG at West Virginia University, Morgantown. We're
>> using 2.4. My question - the sound delays approximately 7.5 seconds (the
>> video is about .5 which is understandable). What could cause such a large
>> delay? I don't think it's congestion; we tried the Lobby as well as the
>> Test Room; the results were the same. One reason I'm curious - I work at
>> times in sound and it would help to understand the mechanism here.
>> Thanks, Alan, sondheim at panix.com
>> blog at http://nikuko.blogspot.com - for URLs, DVDs, CDs, books/etc. see
>> http://www.asondheim.org/advert.txt - contact sondheim at panix.com, -
>> general directory of work: http://www.asondheim.org
>> Trace at: http://tracearchive.ntu.ac.uk - search "Alan Sondheim"
>> http://clc.as.wvu.edu:8080/clc/Members/sondheim
