[AG-TECH] Venue Server Documentation/Tutorial
    Jeremy Mann
    jeremymann at gmail.com
    Thu Nov 30 13:10:16 CST 2006
Jim, unfortunately no, there isn't. I have asked for awhile now on updated
documentation., but here is what I've learned.
1. If running concurrently with a 2.4 server on the same machine, start the
venue server like so (we run 2.4 on port 8000 and 3.0.2 on 9000):
VenueServer3.py -c VenueServer3.cfg --port 9000
Note, you can use a 2.4 config file, but you'll need to remove the line
"authorizationPolicy".
2. Starting the bridge server:
Bridge3.py -p 20000 -r 25000 26000 -n UTHSCSA AG3 Bridge -l Texas -u
http://www.accessgrid.org/registry/peers.txt
Obviously change -r to a port range you want and -n is the name that appears
in the client.
That's about it. The rest you can do with VenueManagement.
On 11/30/06, Jim Miller <millerjw at psc.edu> wrote:
> Is there a tutorial for the setup of an AG3 VenueServer?  I found the
> Venue Management Manual, but after reading though it it seems to be for
> AG2.x.
> Thanks,
> -Jim
Jeremy
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20061130/60f8257e/attachment.htm>
