[AG-TECH] osprey 230 suse 10.1
Stuart Poulton
stuart.poulton at astro.le.ac.uk
Mon Nov 27 03:11:49 CST 2006
I too am having problems with Osprey and Suse10.1, having moved from FC2
(which worked without a flaw)
I can get output from 2 of the cards, however the other two cards
produce the plain blue screen output, this is when using bot AG
software, xawtv, and gnomemeeting.
Any advice please ?
Cheers
Stuart
On Thu, 2006-08-24 at 15:20 -0500, Rene Salmon wrote:
> Hi list,
> We have some osprey 230 cards on a suse 10.1 box. All the bttv drivers
> load fine out of the box from suse.
> The problem is that when I startup the AG toolkit software all I get is
> a blue screen. I had the same problem in windows and all I did was
> start up the viewcast sotware and tell it it use the s-video input and
> everything worked.
> I tried using the VIC to select s-video but that does not seem to work I
> still get a blue screen. Is there a way to tell the kernel via a module
> option to use the s-video input on the cards?
> thanks.
> Rene
