[AG-TECH] Can not import certificate on AG 3.0
NamGon Kim
ngkim at netmedia.kjist.ac.kr
Thu May 25 20:51:52 CDT 2006
Hi, all.
I requested a server certificate for AG 3.0 and get the certificate.
I exported this certificate using certificate manager.
I tried to import it on the other Linux machine.
I could select the certificate file, but the 'import' button didn't make
any change.
Does any one have this kind of error? Below is the error log.
Namgon.
[ace at audiocapture ~]$ CertificateManager Traceback (most recent call
last):
File "/usr/lib/python2.3/site-packages/AccessGrid/UIUtilities.py",
line 364, in OnTextLoseFocus
self.fileSelectCB(self, self.path)
File
"/usr/lib/python2.3/site-packages/AccessGrid/Security/wxgui/ImportIdenti
tyCertDialog.py", line 224, in OnCertSelect
classify = CertificateRepository.ClassifyCertificate(path)
File
"/usr/lib/python2.3/site-packages/AccessGrid/Security/CertificateReposit
ory.py", line 127, in ClassifyCertificate
log.error("Could not open certificate file %s", path)
File "/usr/lib/python2.3/logging/__init__.py", line 923, in error
apply(self._log, (ERROR, msg, args), kwargs)
File "/usr/lib/python2.3/logging/__init__.py", line 994, in _log
self.handle(record)
File "/usr/lib/python2.3/logging/__init__.py", line 1004, in handle
self.callHandlers(record)
File "/usr/lib/python2.3/logging/__init__.py", line 1037, in
callHandlers
hdlr.handle(record)
File "/usr/lib/python2.3/logging/__init__.py", line 592, in handle
self.emit(record)
File "/usr/lib/python2.3/logging/handlers.py", line 670, in emit
self.flush()
File "/usr/lib/python2.3/site-packages/AccessGrid/Log.py", line 434,
in flush
h.handle(record)
self.emit(record)
File "/usr/lib/python2.3/logging/handlers.py", line 102, in emit
msg = "%s\n" % self.format(record)
File "/usr/lib/python2.3/logging/__init__.py", line 567, in format
return fmt.format(record)
File "/usr/lib/python2.3/logging/__init__.py", line 365, in format
s = self._fmt % record.__dict__
UnicodeDecodeError: 'ascii' codec can't decode byte 0xb3 in position 4:
ordinal not in range(128)
** (python:532): WARNING **: Invalid UTF8 string passed to
pango_layout_set_text()
pango_layout_set_text() Traceback (most recent call last):
line 403, in OnBrowse
File
File
ory.py", line 131, in ClassifyCertificate
log.info("Found valid cert, validKey=%s", validKey)
File "/usr/lib/python2.3/logging/__init__.py", line 893, in info
apply(self._log, (INFO, msg, args), kwargs)
self.handle(record)
callHandlers
hdlr.handle(record)
self.emit(record)
self.flush()
in flush
h.handle(record)
self.emit(record)
ordinal not in range(128) Traceback (most recent call last):
File
tyCertDialog.py", line 326, in OnImport
classify = CertificateRepository.ClassifyCertificate(certPath)
File
self.handle(record)
callHandlers
hdlr.handle(record)
self.emit(record)
self.flush()
in flush
h.handle(record)
self.emit(record)
File
File
self.handle(record)
callHandlers
hdlr.handle(record)
self.emit(record)
self.flush()
in flush
h.handle(record)
self.emit(record)
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060526/eb8a9a34/attachment.htm>
