[AG-TECH] Autoplace
Socrates
socratez at gmail.com
Mon May 15 08:17:59 CDT 2006
Hi Roman,
There is also the new UCL Subversion repository and Trac content management
system of the media tools (including rat and the common library), supported
by the SUMOVER project:
https://frostie.cs.ucl.ac.uk/nets/mmedia
http://www.cs.ucl.ac.uk/research/sumover/
We are in touch with the ANL guys and other contributors to integrate AG
vic/rat features and other patches into our Subversion repository in the
short future, so any contributions you may have are also welcome.
Socrates.
On 5/15/06, Breuer, Roman <rbreuer at rz.rwth-aachen.de> wrote:
> Tom,
> I think that the policy autoplace uses is not that, what I want. I don't
> know how much work it will be, but the points I don't like are:
> 1) When you draw the placing area, the resulting placing grid is
> computed with respect to the selected window size. When you the select
> an other window size the grid is not computed again.
> 2) The placing grid does not consider the display borders. So windows
> are sometimes shown half on one display and half on the other display.
> That's not acceptable especially when the displays are surrounded with
> frames such as rear projections or SMARTboards.
> 3) The placing area has to be shown everytime. Even if you close and
> reopen autoplace.
> That are some points I would like to change. I hope it is OK, that I
> will so this. Or are there any restrictions in changing the code? Or are
> there already any attempts for those changes?
> Regards and good luck for the AG-Retreat2006. Unfortunately I could not
> come :(
> Roman
> Dipl.-Inform. Roman Breuer
> Multimedia und Video
> Rechen- und Kommunikationszentrum der RWTH Aachen
> Seffenter Weg 23
> 52074 Aachen
> Germany
> Tel.: +49 (0) 241 / 80 29247
> Fax: +49 (0) 241 / 80 6 29247
> Web: http://www.rz.rwth-aachen.de
> > -----Original Message-----
> > From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> > Sent: Friday, May 12, 2006 5:54 PM
> > To: Breuer, Roman
> > Cc: ag-tech at mcs.anl.gov
> > Subject: Re: [AG-TECH] Autoplace
> > Hi Roman:
> > That functionality is only in the AccessGrid vic, in the
> > autoplace_ui.tcl file,
> > in the ag-media cvs module. You can view the file online here:
> > http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/ag-
> > media/vic/tcl/autoplace_ui.tcl
> > If you're building on Linux, I'd recommend that you use the vic-build
> > script.
> > On Windows, we use something like this:
> > cd ag-media
> > devenv vic\vic.sln /build "DDraw Release"
> > Can you say more about the changes you plan for autoplace?
> > Tom
> > Breuer, Roman wrote:
> > > Hi everyone,
> > > I think my last mail was somehow not delivered to this list (or
> maybe I
> > > wrote to the wrong list ...), but can anyone tell me where I can
> find
> > > the sources of the vic-autoplace functionality. And how to rebuild
> vic
> > > for AG, after changing a few things? Maybe there are websites I have
> not
> > > discovered yet, with this info I need.
> > > Best Regards,
> > > Roman
> > > Seffenter Weg 23
> > > 52074 Aachen
> > > Germany
Socrates.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060515/16d4fdb9/attachment.htm>
