[AG-TECH] Gentoo build
Niall Moran
niall.moran at ichec.ie
Fri Mar 31 10:56:11 CST 2006
The gentoo build seems to be broken alright. I managed to get around
this problem with
export GPT_LOCATION=/usr/lib/gpt-3.1
Then I got more build errors about insecure binaries. I got around these
by adding -static directives to the globus-data-management-client so
that the gpt build lines looked like
${GPT_LOCATION}/sbin/gpt-build -verbose -static ${WORKDIR}/${A}
gcc32pthr
gcc32dbgpthr
This involved placing the updated md5sum in the manitfest etc...
Then this installs. But had to manually build these again without the
static flags to get the required libraries in place.
After this the build should work fine. I have this in use as a venue
server where everything works fine. However on a client when trying to
create a proxy cert from anything but an anonymous cert I get a seg
fault. Everything else works fine however.
Hope this helps. Its been a while since I did this so details are a bit
flaky. I can probably dig up some more details instructions if you need
them.
Cheers,
Niall.
| Niall Moran
| Systems Administrator
| Irish Centre for High-End Computing
\niall.moran at ichec.ie
On Fri, Mar 31, 2006 at 09:51:11AM -0600, Jeremy Mann wrote:
> I'm trying to build the AG 2.4 release on a Gentoo machine and I get the
> following error:
> >>> Install globus-data-management-client-2.4.3-r3 into
> /var/tmp/portage/globus-data-management-client-2.4.3-r3/image/
> category globus-client
> !!! ERROR: globus-client/globus-data-management-client-2.4.3-r3 failed.
> !!! Function src_install, Line 35, Exitcode 0
> !!! Then environment variable GPT_LOCATION must be set
> !!! If you need support, post the topmost build error, NOT this status
> message.
> How can I fix this error?
> Jeremy Mann
> jeremy at biochem.uthscsa.edu
> University of Texas Health Science Center
> Bioinformatics Core Facility
> http://www.bioinformatics.uthscsa.edu
> Phone: (210) 567-2672
Name: not available
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060331/daf95a0c/attachment.pgp>
