[AG-TECH] vic and rat encryption
Colin Perkins
csp at csperkins.org
Thu Mar 30 09:38:53 CST 2006
We might want to hack the code to make "AES" an accepted spelling of
Rijndael? :-)
Colin
On 30 Mar 2006, at 14:26, Derek Piper wrote:
> Heheh.. yea.. quite right. Ooops. I hate that word for how often I
> misspell it. I really had to make sure I got it right in the source
> code for AGVCR. For emails, obviously I'm still having problems. :)
> Derek
> Piers O'Hanlon wrote:
>> Hi,
>> Just a minor correction - just a typo - to save frustration:
>> One needs use "Rijndael/" instead of "Rjindael/"
>> Piers.
>> On 3/29/06, Derek Piper <dcpiper at indiana.edu> wrote:
>>> You may be better off using Rjindael encryption, which is
>>> normally used
>>> on AG Venues when setting the 'encryption' option in the venue
>>> server
>>> config.
>>> A Rjindael key is passed to VIC and RAT as 'Rjindael/
>>> passphrase' where
>>> passphrase should be something random and unguessable, and
>>> distributed
>>> to those needing the key to enter manually. There's a program for
>>> Debian
>>> called 'pwgen' that I've used to generate a passphrase before. For
>>> manually entering the key, you would probably just disable the venue
>>> encryption and manually key it in. For a DES key, just use a
>>> passphrase
>>> that doesn't start with a string 'Rjindael/'.
>>> Of course you can also use certificates to secure a venue
>>> too, so not
>>> just anyone can enter and obtain the encryption key.
>>> Derek
>>> Jeremy Mann wrote:
>>>> We would like to demonstrate encryption in April to some fellow
>>>> colleagues. I set up a test room on our venue server with
>>>> encryption.
>>>> Encryption works fine, but whoever enters the venue gets the
>>>> encryption
>>>> key. I would like to "lock" down the room to whoever I give the
>>>> key to,
>>>> not whoever enters the room. Can this be done?
>>>> Also, I know I can manually enter a key into vic and rat. Is
>>>> there a
>>>> program that I can run to get DES key? Or can I simply use a
>>>> passphrase
>>>> instead?
>>>> Thanks!
>>> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
>>> IRI 323, School of Informatics
>>> Indiana University, Bloomington, Indiana
