[AG-TECH] vic and rat encryption
Derek Piper
dcpiper at indiana.edu
Wed Mar 29 14:00:55 CST 2006
Ah, I was not aware of that :) Good to know indeed.
Derek
Andrew Rowley wrote:
> Hi,
> Note that inSORS nodes don't support Rijindael as far as I know, so you will have to use DES.
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Jeremy Mann
> Sent: 29 March 2006 17:28
> To: 'Derek Piper'
> Cc: 'ag-tech at mcs.anl.gov'
> Subject: Re: [AG-TECH] vic and rat encryption
> Derek Piper said:
>> You may be better off using Rjindael encryption, which is normally
>>used on AG Venues when setting the 'encryption' option in the venue
>>server config.
>> A Rjindael key is passed to VIC and RAT as 'Rjindael/passphrase'
>>where passphrase should be something random and unguessable, and
>>distributed to those needing the key to enter manually. There's a
>>program for Debian called 'pwgen' that I've used to generate a
>>passphrase before. For manually entering the key, you would probably
>>just disable the venue encryption and manually key it in. For a DES
>>key, just use a passphrase that doesn't start with a string 'Rjindael/'.
>> Of course you can also use certificates to secure a venue too, so not
>>just anyone can enter and obtain the encryption key.
> The certificate security can not be done because half the participants are inSORS nodes. I'll try out this pwgen and test it out. Thanks!
> Jeremy Mann
> jeremy at biochem.uthscsa.edu
> University of Texas Health Science Center
> Bioinformatics Core Facility http://www.bioinformatics.uthscsa.edu
> Phone: (210) 567-2672
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
