[AG-TECH] noise reduction
Chris Rosenthal
cmr.evl at gmail.com
Thu Jun 8 11:24:42 CDT 2006
Lisa,
One thing to consider is that the XAP 800 does noise cancellation along with
echo cancellation. We're still using an older model that only does echo,
but this should help you take care of the noise problem in the room. Others
on the list can probably speak to how well it works for noise cancellation.
http://www.clearone.com/products/product.php?cat=1&prod=1
You should also consider the pickup pattern of your mics and try to keep
them away from the extra noise where possible.
Cheers,
Chris
On 6/8/06, Lisa Metz <lmetz at engr.colostate.edu> wrote:
> Good morning,
> I am a project lead for an AG node at CSU. The room we are considering
> using is quite noisy and we're trying to find the best possible solution
> for this issue.
> Short of re-locating the room (or the two large air-conditioning units)
> I'm
> looking for microphones that might help with noise reduction. Has anyone
> else dealt with noise reduction successfully by using a specific brand or
> type of microphone? Or used any other tricks of the trade?
> Thanks in advance for any help!
> Lisa Metz
> Lisa Metz
> Computer Support Analyst
> Engineering Network Services
> Phone: 491-3465
> Email: lmetz at engr.colostate.edu
> "You must be the change you want to see in the world"
> -Mahatma Gandhi
Chris Rosenthal
Electronic Visualization Laboratory
University of Illinois - Chicago
Phone: 312.996.3002
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060608/f6986874/attachment.htm>
