[AG-TECH] BridgeServer
    S.Booth
    spb at epcc.ed.ac.uk
    Thu Jun  1 03:06:15 CDT 2006
On Tue, 30 May 2006, Mike Daley wrote:
> I have been running a Bridgeserver and venue server on the same machine for a
> while but it becomes very sluggish.
I would be interested to know if its the python part of the Bridgeserver
or the quickbridges that are causing the sluggishness.
I guess you can tell this by looking to see if the quickbridges are
running.
   I have always been a bit worried by the load caused by quickbridge.
A quickbridge with no clients should not use any resources as the process
blocks in a select call but if you are running multiple active bridges at
the same time then you are going to get a lot of process thrashing as the
CPU switches between the bridges.
  Actually QB is written so a single process can bridge multiple streams at
the same which might aleviate the problem a bit. It would probably not be
too hard to write a version of QB which sets up a session on a single
forwarding process rather than forwarding the packets directly.
 				Stephen
|epcc| Dr Stephen P Booth             Principal Architect       |epcc|
|epcc| s.booth at epcc.ed.ac.uk          Phone 0131 650 5746       |epcc|
