[AG-TECH] Fail to add service manager in AG2.4
Zephyr Zhangbo Liu
zephyr at cs.ubc.ca
Thu Jul 27 14:09:21 CDT 2006
I'm trying to add the Video Producer Service and Audio Service from
video/audio machine to display/control machine. I did the following things:
1. Added those service in the NodeManagement of video/audio machine.
2. Opened the ServiceManager in the video/audio machine.
3. Opened VenueClient (in debug mode) in display/control machine and tried
to add the ServiceManager using the host name of the video/audio machine.
But got errors.
I've attached the error messages it showed in the debug window since I don't
understand what's wrong with it. Could anyone check and know how to fix it?
My node configuration is:
Video/Audio machine: x86_64 SUSE 10.1
Display/Control machine: x86_64 WinXP
Thanks a lot,
Zephyr
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060727/2f190891/attachment.htm>
07/27/06 11:50:09 3804 NodeService __init__.py:988 INFO service manager ur
i = https://accessgrid4.cs.ubc.ca:11000/ServiceManager
07/27/06 11:50:30 3804 NodeService __init__.py:988 ERROR Failed to add servi
ce manager https://accessgrid4.cs.ubc.ca:11000/ServiceManager
Traceback (most recent call last):
File "C:\AccessGrid\Software\Python23\lib\site-packages\AccessGrid\AGNodeServi
ce.py", line 156, in AddServiceManager
AGServiceManagerIW( serviceManager.uri ).IsValid()
File "C:\AccessGrid\Software\Python23\lib\site-packages\AccessGrid\hosting\SOA
PInterface.py", line 214, in IsValid
return self.proxy.IsValid()
File "C:\AccessGrid\Software\Python23\lib\site-packages\SOAPpy\Client.py", lin
e 453, in __call__
return self.__r_call(*args, **kw)
e 475, in __r_call
self.__hd, self.__ma)
e 347, in __call
config = self.config)
e 187, in call
r.endheaders()
File "C:\AccessGrid\Software\Python23\lib\httplib.py", line 715, in endheaders
self._send_output()
File "C:\AccessGrid\Software\Python23\lib\httplib.py", line 600, in _send_outp
ut
self.send(msg)
File "C:\AccessGrid\Software\Python23\lib\httplib.py", line 567, in send
self.connect()
File "C:\ACCESS~1\Software\Python23\lib\site-packages\pyGlobus\io.py", line 10
93, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\ACCESS~1\Software\Python23\lib\site-packages\pyGlobus\io.py", line 67
1, in connect
raise ex
GSITCPSocketException: a system call failed (Unknown error)
*** Method NodeService:AddServiceManager exception *********************
File "C:\AccessGrid\Software\Python23\lib\site-packages\SOAPpy\Server.py", lin
e 408, in do_POST
fr = apply(f, ordered_args, named_args)
ce.py", line 855, in AddServiceManager
self.impl.AddServiceManager(serviceManagerDesc)
e 453, in __call__
e 475, in __r_call
e 347, in __call
e 187, in call
r.endheaders()
self._send_output()
ut
self.send(msg)
self.connect()
93, in connect
1, in connect
raise ex
<Fault SOAP-ENV:Server: Method Failed: NodeService:AddServiceManager>
07/27/06 11:50:31 1596 NodeManagementUIClasses __init__.py:988 ERROR Excepti
on in AddHost
File "C:\AccessGrid\Software\Python23\lib\site-packages\AccessGrid\NodeManagem
entUIClasses.py", line 772, in AddHost
self.nodeServiceHandle.AddServiceManager( serviceManagerDesc )
ce.py", line 1137, in AddServiceManager
self.proxy.AddServiceManager(serviceManager)
e 453, in __call__
e 475, in __r_call
e 389, in __call
raise p
faultType: <Fault SOAP-ENV:Server: Method Failed: NodeService:AddServiceManager>
