[AG-TECH] Problem with BridgeServer
Sebastian Tabarce
stabarce at inescporto.pt
Mon Feb 27 09:29:24 CST 2006
Hello!
I have the folowing setup for an AG Venue Server and an AG Bridge Server:
- the Venue Server: one machine running Fedora Core 4 and AGTK 2.4. This
machine has the internal IP 192.168.103.55 and the domain name
silicon.fe.up.pt. This machine has linked to it the real IP address
193.136.28.183. I don't know exactly what this means in terms of
networking, I just asked my network admin to make my machine visible to
the Internet and he told me that my machine can be seen from the
Internet with this address and also by its name silicon.fe.up.pt. Ports
8000, 8002, 8004, 8006 TCP are opened for this machine.
- the Bridge Server is running Slackware 10 and AGTK 2.4. Same as above,
internal IP is 192.168.103.62, external IP is 192.136.28.184. and name
poly.fe.up.pt. Ports 50000-50010 UDP are opened.
I've conducted some tests. On the internal network everything works
fine. From outside, people can connect to my Venue Server using
https://silicon.fe.up.pt:8000/Venues/default , they see the BridgeServer
and can choose Unicast, however they do not appear in my RAT window and,
of course, I cannot talk to them. Multicast is not an option. Also no
output in the terminal of the BridgeServer for machines trying to
connect from outside. For those on the local network I have the normal
output.
Any thoughts about why the Bridge Server is not doing its job?
Sebastian
Sebastian Tabarce
Junior Researcher
INESC Porto
Campus da FEUP - Rua Dr. Roberto Frias, nº 378
4200-465 Porto Portugal
E-mail : stabarce at inescporto.pt
Web : http://www.inescporto.pt
