[AG-TECH] One-page summary of AG port usage -- please help us complete it
    R. P. Channing ["Rick"] Rodgers
    rodgers at nlm.nih.gov
    Mon Feb 13 13:42:49 CST 2006
Yes!  SIP would clear it up, though I can understand why no one is jumping
into that, given the work involved.  :)  Our port list would be very helpful
in the interim.
> X-SBRS: 4.2
> X-BrightmailFiltered: true
> X-Brightmail-Tracker: AAAAAA==
> Mime-Version: 1.0 (Apple Message framework v746.2)
> Cc: ag-tech at mcs.anl.gov, judson at mcs.anl.gov, terrazas at labmed2.ucsf.edu
> Content-Transfer-Encoding: 7bit
> From: Colin Perkins <csp at csperkins.org>
> Subject: Re: [AG-TECH] One-page summary of AG port usage -- please help us
complete it
> Date: Mon, 13 Feb 2006 19:26:13 +0000
> To: "R. P. Channing [\"Rick\"] Rodgers" <rodgers at nlm.nih.gov>
> X-OriginalArrivalTime: 13 Feb 2006 19:26:20.0438 (UTC)
FILETIME=[5E43EB60:01C630D3]
> On 13 Feb 2006, at 19:05, R. P. Channing [Rick] Rodgers wrote:
> >> From: "Ivan R. Judson" <judson at mcs.anl.gov>
> >> Subject: RE: [AG-TECH] One-page summary of AG port usage -- please
> >> help us
> > complete it
> >> Date: Mon, 13 Feb 2006 11:41:32 -0600
> >> I think what you're hearing is unwillingness for anyone to commit
> >> to a wrong
> >> answer.
> >> From memory, the ports for vic, rat, and the rest of the tools are
> >> allocated
> >> by the venue server. It can be a static allocation configured by the
> >> provider or a dynamic allocation (I think the default).
> > Perhaps my understanding is faulty, but I also believe that the
> > default is
> > automated assignment by the server.  But that can not be entirely
> > random --
> > the numbers must be drawn from a range of values appearing
> > somewhere in the
> > code.  Having that range in a doc. is much better than having nothing,
> > which is what he have now.
> > A subsequent posting from Zsolt Nagykaldi makes the point, which I
> > emphatically
> > agree with, that port assignment is a crucial problem to solve if
> > AG is truly
> > going to take off.  He suggests using fixed port numbers with a
> > registry, which
> > is one solution (and by "fixed" I believe he means that required
> > ports would
> > remain the same for a given venue over time).  Another might be to
> > adapt or
> > create a protocol allowing the exchange of port numbers when
> > entering a venue
> > (which would at least tell you what ports were required, even if
> > they don't
> > happen to be open at the moment).
> A long term solution along these lines would be to adopt SIP as part
> of the signalling mechanisms for AccessGrid, since many firewall/NAT
> devices these days are becoming SIP aware to support VoIP
> applications, and can snoop on the signalling to open the required
> ports. That's a huge job though, and not a near term solution...
> Colin
R. P. C. Rodgers, M.D. * rodgers at nlm.nih.gov * (301)435-3267 (voice, fax)
OHPCC, LHNCBC, U.S. National Library of Medicine, NIH
Bldg 38, Rm. B1N-30F2, 8600 Rockville Pike, Bethesda MD 20894 USA
http://lhc.nlm.nih.gov/staff/rodgers/rodgers.html
