[AG-TECH] Concurrent AG3 & AG2.4 on Fedora
Douglas Kosovic
douglask at itee.uq.edu.au
Mon Feb 6 15:50:35 CST 2006
Hi Todd,
> I'm keen to test out the AG3.x VenueClient - and especially the
> VenueServer but saw this on the website:
> "AccessGrid-3.0-0.beta1 RPM can not be installed on systems with earlier
> AccessGrid RPMs"
> Is there anyway to run AG3 concurrently w/ AG2.4 on Fedora??
Not at the moment. I have to release new AGTk 2.4 and 3.0 (beta) RPMs to be
able to have them co-installed.
The AccessGrid 2.4 RPM is a monolithic RPM which contains python packages
like pyOpenSSL_AG which clashes with a 3.0 (beta) install. There are also
clashes with FC5's Fedora Extras 5 python packages, so the AccessGrid 2.4
RPM is going to get split up into multiple RPMs (much like the AGTk 3 beta
RPMs).
The names of the executables under /usr/bin will have to be changed to avoid
clashes (e.g VenueClient -> VenueClient3), similarilarly for the menu
entries and /etc/AccessGrid dir rename to /etc/AccesssGrid3. The most
important change is the python site-packages dir:
/usr/lib/python2.4/site-packages/AccessGrid/
which might split up into something like:
_init__.py
AccessGrid2
AccessGrid3
The __init__.py file will probably set the sys.path variable (i.e equivalent
of PYTHONPATH) possibly using a mechanism similar to how wxPython is able to
have multiple versions installed at the same time. But it hasn't been
decided yet how to do it under any linux distro. Minor modifications to
sharedapps' code may be required to select the required AGTk version
Cheers,
Doug
