[AG-TECH] Windows users
Michael Miller
mimiller at ncsa.uiuc.edu
Thu Aug 10 08:23:29 CDT 2006
Martin,
If you copy the C:\doc..\<user>\Application Data\AccessGrid folder to
the AllUsers profile, all new logins will acquire that folder when their
profile is first set up. For users already on the system, a simple
batch file to copy that folder to all current profiles would work.
One caveat is that all the users will need to acquire their own
certificate, unless of course you want to give out the password for the
current cert and have each user use the same credentials for all AG
sessions.
hth
myk
Martin Stenlake wrote:
> In Windows XP (AG 3.0.2) is there a way of copying the installation
> and configuration settings so that they are available to "all users".
> By default these settings are only available to the user who does the
> installation, this will most likely be the "administrator" and any
> settings, including certificates, are then not available for
> "ordinary" users, even if they have admin rights.
> Best Regards
> Martin
> Martin Stenlake
> IT Support
> Physics, Elec. Eng. & Maths
> Loughborough University
> Loughborough
> Leicestershire
> LE11 3TU
> United Kingdom
Thanx,
Michael Miller
System Engineer
Video Technology Services
Persistent Infrastructure Directorate
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
