[AG-TECH] AGConnector AG3
Fabrizio.Berdondini at prototipo.it
Thu Aug 3 04:39:25 CDT 2006
I'm sorry of not being able to help you about the use of the AG connector
for AG3, unfortunately we are still trying to build up our
venueserver/nodes based on the AG2.4. However you experience of it on the
2.4 could be very precious to us. We tried using the AGconnector (in order
to bypass NAT/firewall problems) but with no luck: after a while we get
the message telling that the server used for the connector was
unreacheable. Which AG connector server URL should be use to have it work?
Thank you very much for your help,
Faber B.
owner-ag-tech at mcs.anl.gov scritti il 01/08/2006 22:58:16
> Hi
> Has anyone used AGConnector with AG3?
> I,ve installed the package and umtp_win32.exe shows up in the task
> manager but it does not appear to be working. I always had good
> results with AG2.4 and AGConnector from Home.
> Thanks
> Mike
> This message was sent using IMP, the Internet Messaging Program.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060803/74c19805/attachment.htm>
