[AG-TECH] AG 3.0 beta 2 - Video Capture not working
    Nathan Gardiner
    nathan.gardiner at canterbury.ac.nz
    Mon Apr 24 21:56:35 CDT 2006
Hi Tom,
Thanks so much. It works great!
Just one small thing. It's seem to have defaulted back to 320 x 240 for
each of the video streams which gives a grey border box around each of
the videos. I try to change it with vidcap.exe back to 352 x 288 and
reload Access Grid but it doesn't seem to work. Any suggestions?
Many thanks,
Nathan
-----Original Message-----
Sent: Tuesday, 25 April 2006 10:03 a.m.
To: Nathan Gardiner
Subject: Re: [AG-TECH] AG 3.0 beta 2 - Video Capture not working
Hi Nathan:
The problem is apparently with the vic executable in the package that
you have installed.  It is not recognizing WDM-based capture drivers,
even though it should be.  If you take this vic executable:
http://www.mcs.anl.gov/~turam/AG/vic.exe
and copy it to
C:\Documents and Settings\<you>\Application
Data\AccessGrid3\local_services\VideoProducerService
and then try again, you should no longer be prompted to select a video
input for each stream.
This will serve as a test in your case, for you as a user.  This working
vic will be included in the upcoming AG3 release, so the problem will be
generally fixed.
Let me know if this works out for you.  Thanks for testing the beta!
Tom
On 4/23/06 3:35 PM, Nathan Gardiner wrote:
> Hi Tom,
> Thanks for your reply.
> 1. I am using WDM drivers for the Spectra8 card. I don't think there
> are any VFW drivers available for this card.
> 2. It says in the device button under vic that it is using the
> Microsoft WDM Image Capture (Win32) for each vic stream. (by the way,
> I only have two video captures on and I have disabled the other two on
> the card as I don't currently use them)
> It would be so great to get this working as we have 9 sites here in
> New Zealand with the same setup. :) I have also attached photos to
> help. Let me know if you need me to do any further testing. More than
> happy to help.
> Kind regards,
> Nathan Gardiner
> Human Interface Technology Lab NZ (HIT Lab NZ) Room 110, Old Maths
> Building, University of Canterbury
> DDI: +64 3 364 3072, Cell: +64 21 163 2956, http://www.hitlabnz.org
> From: Thomas D. Uram [mailto:turam at mcs.anl.gov]
> Sent: Friday, 21 April 2006 5:05 p.m.
> To: Nathan Gardiner
> Cc: ag-tech at mcs.anl.gov
> Hi Nathan:
> What you are hoping for is intended to be possible with AG3.  I have
> confirmed this working with a Winnov videum card and with multiple USB
> and firewire cameras, all at the same time (I have an iTuner Spectra,
> too; I'll have to try that).
> I'll try to
> help you resolve the problem to ensure that AG3 will do what you're
> after.   A
> couple
> questions:
> - Do you have VFW or WDM drivers installed for the card?
> - Do the individual spectra capture devices appear in vic?  (Select
> Menu, then the Device button)
> Cheers,
> Tom
> On 4/20/06 11:39 PM, Nathan Gardiner wrote:
>> Hi there,
>> I am testing out the AG 3.0 beta 2 downloadable from the Access Grid
>> website. I am using Windows XP SP2 with a Spectra 8 4 port video
>> capture card.
>> Currently in AG 2.4 I have to select each video feed when entering a
>> venue. What I was hoping to achieve and what I believe has been
>> accomplished in the new version was to get the video feeds from the
>> Spectra card to automatically detect each video feed and load up
>> without me having to manually select them. But it appears as though
>> it
>> is still the same. I still have to manually select each video feed.
>> I have noticed though in Manage My Node that the Spectra video feeds
>> do appear when I add a video producer. I select these individual
>> video
>> feeds and save the settings.
>> I thought the previous version being installed on the same pc may be
>> the cause of this problem, so I completed uninstalled everything and
>> then only reinstalled AG 3.0 beta 2 but still this problem appeared.
>> Has anyone else had this problem? Can this problem be overcome?
>> Many thanks,
>> **Nathan Gardiner***
>> *Human Interface Technology Lab NZ (HIT Lab NZ) Room 110, Old Maths
>> <http://www.hitlabnz.org/>
