[AG-TECH] Suse 10 64bit
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Apr 11 17:39:14 CDT 2006
On Tue, 2006-04-11 at 15:35 -0500, Jeremy Mann wrote:
> I compiled everything finally and made RPMs. When starting without
> --personalNode it works just fine. Adding --personalNode gives a
> Seqmentation Fault. What can I look for to track this down?
Try the --debug switch or look in the logs in ~/.AccessGrid/Logs.
If it's Globus related, you could build the debug version of pyGlobus:
http://www.vislab.uq.edu.au/accessgrid3/fedora/5/SRPMS/pyGlobus-gccdbgpthr-1.0.10-2.fc5.src.rpm
On FC5, the debug version of pyGlobus works, but the normal one doesn't.
Doug
