[AG-TECH] Ag 2.4 Build for Suse 10
    Jeremy Mann
    jeremy at biochem.uthscsa.edu
    Tue Apr 11 15:18:27 CDT 2006
Update, I used the FC4 i386 rpm for RAT. Installed just fine.
Douglas Kosovic said:
> On Tue, 2006-04-11 at 13:51 -0500, Jeremy Mann wrote:
>> Great! Thanks Douglas. Is there a proper order to compile these in?
>> > I now use real SRPMs to build everything and the SRPMs can be found
>> here:
>> >     http://www.vislab.uq.edu.au/accessgrid3/fedora/
>> > if you want to build compat-AccessGrid-2.4 on Suse, grab the
>> folllowing
>> > SRPMs:
>> >   AccessGrid-rat
>> >   AccessGrid-vic
>> >   QuickBridge
>> >   globus-accessgrid
>> >   pyOpenSSL_AG
>> >   python-SOAPpy
>> >   python-fpconst
>> > then rpmbuild --rebuild them.
> I should have added pyGlobus to the above list.
> compat-AccessGrid-2.4 needs to be built and installed last. pyGlobus
> after globus-accessgrid and python-SOAPpy after python-fpconst.
> I wouldn't worry too much about the build order as the BuildRequires in
> the spec files will let you know if a build dependency isn't getting
> satisfied when you try to rpmbuild each of the RPMs.
> I should also mention that AccessGrid-rat-4.2.22-*cvs*.src.rpm (i.e. ANL
> CVS rat) can only be built as a 32bit RPM, it might be able to be built
> by setting the rpmbuild --target arch argument to i586 (or however 32bit
> RPMs get built on Suse x86-64). If it doesn't want to get built as
> 32bit, you may need to build rat on a 32bit Suse instead.
> There is also a 64bit clean
> AccessGrid-rat-4.2.22-20051206darcs.*.src.rpm (i.e from Steve Smiths
> darcs repository) which would build as either 32bit or 64bit. The 32bit
> built rat seems to have less glitches than the 64bit.
> Cheers,
> Doug.
Jeremy Mann
University of Texas Health Science Center
Bioinformatics Core Facility
http://www.bioinformatics.uthscsa.edu
Phone: (210) 567-2672
