[AG-TECH] vic and rat encryption
    Derek Piper
    dcpiper at indiana.edu
    Mon Apr  3 15:07:11 CDT 2006
	Heh, that's cool. I added it to AGVCR the other day when Colin
mentioned it.. Great if it's going to be in the media cvs too :)
	Derek
Thomas D. Uram wrote:
> Reading this thread post-vacation, I was thinking the same thing, so I've
> made those couple lines of changes in the ag-media cvs code (yes, that
> will propagate to UCL eventually, if they'll have it).
> Tom
> On 3/30/06 9:48 AM, Ivan R. Judson wrote:
>> no kidding! :-)
>> --Ivan
>> On Mar 30, 2006, at 8:38 AM, Colin Perkins wrote:
>>> We might want to hack the code to make "AES" an accepted spelling of
>>> Rijndael? :-)
>>> Colin
>>> On 30 Mar 2006, at 14:26, Derek Piper wrote:
>>>>     Heheh.. yea.. quite right. Ooops. I hate that word for how often
>>>> I misspell it. I really had to make sure I got it right in the
>>>> source code for AGVCR. For emails, obviously I'm still having
>>>> problems. :)
>>>>     Derek
>>>> Piers O'Hanlon wrote:
>>>>> Hi,
>>>>> Just a minor correction - just a typo - to save frustration:
>>>>> One needs use  "Rijndael/" instead of "Rjindael/"
>>>>> Piers.
>>>>> On 3/29/06, Derek Piper <dcpiper at indiana.edu> wrote:
>>>>>>        You may be better off using Rjindael encryption, which is
>>>>>> normally used
>>>>>> on AG Venues when setting the 'encryption' option in the venue server
>>>>>> config.
>>>>>>        A Rjindael key is passed to VIC and RAT as
>>>>>> 'Rjindael/passphrase' where
>>>>>> passphrase should be something random and unguessable, and
>>>>>> distributed
>>>>>> to those needing the key to enter manually. There's a program for
>>>>>> Debian
>>>>>> called 'pwgen' that I've used to generate a passphrase before. For
>>>>>> manually entering the key, you would probably just disable the venue
>>>>>> encryption and manually key it in. For a DES key, just use a
>>>>>> passphrase
>>>>>> that doesn't start with a string 'Rjindael/'.
>>>>>>        Of course you can also use certificates to secure a venue
>>>>>> too, so not
>>>>>> just anyone can enter and obtain the encryption key.
>>>>>>        Derek
>>>>>> Jeremy Mann wrote:
>>>>>>> We would like to demonstrate encryption in April to some fellow
>>>>>>> colleagues. I set up a test room on our venue server with
>>>>>>> encryption.
>>>>>>> Encryption works fine, but whoever enters the venue gets the
>>>>>>> encryption
>>>>>>> key. I would like to "lock" down the room to whoever I give the
>>>>>>> key to,
>>>>>>> not whoever enters the room. Can this be done?
>>>>>>> Also, I know I can manually enter a key into vic and rat. Is there a
>>>>>>> program that I can run to get DES key? Or can I simply use a
>>>>>>> passphrase
>>>>>>> instead?
>>>>>>> Thanks!
>>>>>> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
>>>>>> IRI 323, School of Informatics
>>>>>> Indiana University, Bloomington, Indiana
>>>> --Derek Piper - dcpiper at indiana.edu - (812) 856 0111
