[AG-TECH] IVS down?
    Steven Eggerling
    seggerling at gmail.com
    Mon Sep 19 15:24:29 CDT 2005
Well, it was not just me that had the problem connecting. My associate in
Lincoln, NE also had the same problem.
Here is my error log from the VenueClient:
09/19/05 13:41:37 2256 VenueClient venueclient.py:809 DEBUG EnterVenue; url=
https://ivs.mcs.anl.gov:9000/Venues/000001059d2e6d69008c00dd000a005a0d3
09/19/05 13:41:37 2256 CertificateManager certificatemanager.py:1011 INFO
Verifying local proxy cert
09/19/05 13:41:37 2256 CertificateManager certificatemanager.py:663 DEBUG
HaveValidProxy: found proxy ident /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=unomaha.edu/CN=Steven
Eggerling/CN=proxy<http://agdev-ca.mcs.anl.gov/OU=unomaha.edu/CN=StevenEggerling/CN=proxy>
09/19/05 13:41:37 2344 NodeService agnodeservice.py:714 INFO
NodeService.GetCapabilities
09/19/05 13:41:37 2344 NodeService agnodeservice.py:255 INFO
NodeService.GetServices
09/19/05 13:41:40 2760 ServiceManager agservicemanager.py:399 INFO
AGServiceManager.GetServices
09/19/05 13:41:56 2256 VenueClient venueclient.py:705 DEBUG EnterVenue:
Invoke venue enter
09/19/05 13:41:57 2256 VenueClient venueclient.py:670 DEBUG SOAP FAULT:
httpg://ivs.mcs.anl.gov:9000/Venues/000001059d2e6d69008c00dd000a005a0d3 a
system call failed (Invalid argument)
09/19/05 13:41:57 2256 VenueClient venueclient.py:672 ERROR SOAP fault
occurred
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in __call
config = self.config)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
r.endheaders()
File "C:\Python23\lib\httplib.py", line 712, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 597, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 564, in send
self.connect()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
raise ex
GSITCPSocketException: a system call failed (Invalid argument)
09/19/05 13:41:57 2256 VenueClient venueclient.py:857 ERROR EnterVenue:
globus tcp exception: ('a system call failed (Invalid argument)',)
09/19/05 13:41:57 2256 VenueClient venueclient.py:864 ERROR EnterVenue:
failed
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 840, in
EnterVenue
self.__EnterVenue(URL)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 706, in
__EnterVenue
(venueState, self.privateId, self.streamDescList ) =
self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3492, in
Enter
(r1, r2, r3) = self.proxy.Enter(profile)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
self.__hd, self.__ma)
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
On 9/19/05, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> I've just entered the ivs lobby (
> https://ivs.mcs.anl.gov:9000/Venues/default)
> with no trouble. If you describe the symptoms that you're running into, we
> can
> try to help resolve the problem.
> Tom
> On 9/19/05 1:43 PM, Steven Eggerling wrote:
> > Does it happen to be down again today?
> > On 9/12/05, *Thomas D. Uram* <turam at mcs.anl.gov
> > <mailto:turam at mcs.anl.gov>> wrote:
> > The IVS was down. I have restarted it. I'm looking into the cause,
> > which
> > appears to be related to runs of the backup software.
> > Thanks for letting us know.
> > Tom
> > On 9/12/05 12:59 PM, Steven Eggerling wrote:
> > > Hi,
> > > Is IVS down right now or is it just me?
> > > Steven J. Eggerling
> > > Access Grid/IT Administrator
> > > UNL Department of Computer & Electronics Engineering
> > > Web: http://ceen.unomaha.edu/
> > Steven J. Eggerling
Steven J. Eggerling
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050919/724d883f/attachment.htm>
