[AG-TECH] AGTK 2.4 error on IBM ThinkPad
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Tue Sep 13 03:15:48 CDT 2005
In case you are worried about not having the IBM functionality of your
laptop, I have installed a fresh install of Windows XP on my Thinkpad X24.
I then downloaded the IBM pre-installed software such as Access Connections
from the IBM support pages so I can still get the additional IBM
functionality.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Many Ayromlou
> Sent: 12 September 2005 22:25
> To: Dioselin Gonzalez
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] AGTK 2.4 error on IBM ThinkPad
> Hi Dio,
> I've come across this a couple of times with IBM laptops
> specifically. If you have the stock IBM install of XP (or have
> reinstalled it using the restore disks IBM gives you) then more than
> likely you have some version of Python that conflicts with AG
> operation (usually IBM guys have version 2.2 installed). They need
> this to get all the buttons and "IBM Gold standard" services running
> on the laptops. Easy way to check is to check the XP environment vars
> and get rid of anything python2.2 find all python stuff other than
> 2.3 and delete them (or uninstall) and hopefully if you've cleaned it
> enough AG will kick in.
> Personally, I would reinstall XP from a "real" MS WinXP SP-2 CD and
> then do the AG install. Remind you if you do this (or the above
> steps) some of the "ibm" functionality of your laptop (like that
> program they have that lets you switch network preferences and
> profiles) might stop working properly.
> Hope this helps,
> TTYL,
> Many
> On 12-Sep-05, at 3:59 PM, Dioselin Gonzalez wrote:
> > Hi everybody,
> > I am unable to connect on an IBM ThinkPad; I read the archives and
> > deleted the PYTHONCASE and related variables but I still get the
> > FCNTL/TERMIOS deprecation warning and the "invalid service manager
> > url" error so I cannot connect to a venue. Attached is the log file.
> > Any help will be appreciated. Thanks!
> > Dioselin.-
> > 09/12/05 14:53:09 2440 Toolkit config.py:196 DEBUG Using
> > GLOBUS_HOSTNAME=localhost as set in the environment
> > 09/12/05 14:53:09 2440 CertificateManager certificatemanager.py:
> > 269 DEBUG Opened repository C:\Documents and Settings\Dio
> > \Application Data\AccessGrid\Config\certRepo
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:404 DEBUG looking in
> > system ca dir: C:\Program Files\AGTk-2.4\Config\CAcertificates
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:418 INFO C:\Program
> > Files\AGTk-2.4\Config\CAcertificates\1c3f2ca8.0 might be a cert
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:440 INFO Certificate
> > 1c3f2ca8.0 already in repository
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:456 INFO Marking
> > cert as CA cert
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:469 INFO Imported
> > signing policy as C:\Documents and Settings\Dio\Application Data
> > \AccessGrid\Config\certRepo\certificates
> > \a82c3f1c4b096b896061778ee79efeff\9c8df64aa35ebf832613413527bc073d
> > \user_files\signing_policy
> > Files\AGTk-2.4\Config\CAcertificates\45cc9e80.0 might be a cert
> > 45cc9e80.0 already in repository
> > cert as CA cert
> > \809ecc45460c1482e61e26bdfbf9e18c\9f380c9a586af2bb913ace809d5badfe
> > Files\AGTk-2.4\Config\CAcertificates\d1b603c3.0 might be a cert
> > d1b603c3.0 already in repository
> > cert as CA cert
> > \c303b6d10c962b37482e68ca64d383a0\05a2039fe10ed1b4195d9f9d35b32c68
> > Files\AGTk-2.4\Config\CAcertificates\f18fa857.0 might be a cert
> > f18fa857.0 already in repository
> > cert as CA cert
> > \57a88ff1707d87e926f2287c702a8466\eff65f03366cb8e20247f831ccc87fd5
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:478 DEBUG Init'ing
> > globus.
> > 759 DEBUG Configuring standard environment
> > 827 DEBUG Using default identity /O=Access Grid/O=Argonne National
> > Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User
> > 88c4fb7e63b7a97b2b60f0b8b4da8bf0
> > 1083 DEBUG Initializing environment with unencrypted cert /O=Access
> > Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous
> > Authority/CN=Anonymous User 88c4fb7e63b7a97b2b60f0b8b4da8bf0
> > 1098 INFO Setting permissions on certificate C:\Documents and
> > Settings\Dio\Application Data\AccessGrid\Config\certRepo
> > \certificates\2510a202cc38e53d8c975add4ee44f1a
> > \d392ffeeedc9b589aca15521bc6687d7\cert.pem to 644
> > 1109 INFO Setting permissions on certificate C:\Documents and
> > Settings\Dio\Application Data\AccessGrid\Config\certRepo\privatekeys
> > \18730d7920aceaeaa253de692a14dfb6.pem to 600
> > 09/12/05 14:53:09 2440 CertificateManagerWXGUI
> > certificatemanagerwxgui.py:422 DEBUG done, success=1
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:482 DEBUG Done with
> > globus.
> > 09/12/05 14:53:09 2440 VenueClient venueclient.py:287 DEBUG
> > __StartWebService: venueclient: https://localhost:11000/VenueClient
> > 09/12/05 14:53:09 2440 ServiceManager agservicemanager.py:75
> > INFO Using services dir: C:\Documents and Settings\Dio\Application
> > Data\AccessGrid\local_services
> > 09/12/05 14:53:09 2440 ServiceManager agservicemanager.py:424
> > INFO __DiscoverResources
> > 09/12/05 14:53:09 2440 Toolkit config.py:997 INFO Using
> > vfwscan to get devices
> > 09/12/05 14:53:09 2440 Toolkit config.py:998 DEBUG vfwscanexe =
> > C:\PROGRA~1\AGTk-2.4\bin\vfwscan.exe
> > 09/12/05 14:53:09 2440 Toolkit config.py:1003 DEBUG filelines =
> > ['Creative WebCam Notebook Ultra (VFW)\n', 'Microsoft WDM Image
> > Capture (Win32)\n']
> > 09/12/05 14:53:09 2440 Toolkit config.py:1031 INFO
> > GetResources: ['Creative WebCam Notebook Ultra (VFW)', 'Microsoft
> > WDM Image Capture (Win32)']
> > 09/12/05 14:53:09 2440 VenueClient venueclient.py:296 DEBUG
> > __StartWebService: service manager: https://localhost:11000/
> > ServiceManager
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:755 INFO
> > NodeService.__ReadConfigFile
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:335 DEBUG Looking
> > for: C:\Documents and Settings\Dio\Application Data\AccessGrid
> > \Config\AGNodeService.cfg
> > 09/12/05 14:53:09 2440 Toolkit toolkit.py:340 DEBUG Looking
> > for: C:\Program Files\AGTk-2.4\Config\AGNodeService.cfg
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:763 DEBUG
> > DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.4\Config
> > \AGNodeService.cfg
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:767 INFO
> > Reading node service config file: C:\Program Files\AGTk-2.4\Config
> > \AGNodeService.cfg
> > 09/12/05 14:53:09 2440 VenueClient venueclient.py:302 DEBUG
> > __StartWebService: node service: https://localhost:11000/NodeService
> > 09/12/05 14:53:09 2440 VenueClient venueclient.py:1331 DEBUG
> > SerNodeUrl: Set node service url: https://localhost:11000/NodeService
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:697 INFO
> > NodeService.GetDefaultConfiguration
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:580 INFO
> > Migration unnecessary
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:373 INFO
> > NodeService.LoadDefaultConfig
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:377 INFO
> > Loading default node configuration: defaultWindows
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:391 INFO
> > NodeService.LoadConfiguration
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:406 INFO
> > Trying to load node configuration from: C:\Documents and Settings
> > \Dio\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:479 INFO
> > AddServiceManager: Invalid service manager url (https://localhost:
> > 11000/ServiceManager)
> > 09/12/05 14:53:09 2440 NodeService agnodeservice.py:380 ERROR
> > Exception loading default configuration.
> > Traceback (most recent call last):
> > File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
> > line 378, in LoadDefaultConfig
> > self.LoadConfiguration( self.defaultConfig )
> > line 522, in LoadConfiguration
> > raise Exception(exceptionText)
> > Exception: Couldn't reach service manager: localhost:11000
> > 09/12/05 14:53:09 2440 VenueClient venueclient.py:313 ERROR
> > Error loading default configuration
> > File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py",
> > line 311, in __StartWebService
> > self.ns.LoadDefaultConfig()
> > line 381, in LoadDefaultConfig
> > raise Exception("Failed to load default configuration <%s>" %
> > Exception: Failed to load default configuration <defaultWindows>
> > 09/12/05 14:53:09 2440 VenueClient venueclient.py:185 DEBUG
> > __createPersonalDataStore: Creating personal datastore at C:
> > \Documents and Settings\Dio\Application Data\AccessGrid\Config
> > \personalDataStore using prefix personalDataStore and port 0
> > 09/12/05 14:53:09 2440 DataStore datastore.py:1537 DEBUG
> > Creating thread 0
> > 09/12/05 14:53:09 2440 DataStore datastore.py:1542 DEBUG
> > Starting thread 0
> > 09/12/05 14:53:09 2540 DataStore datastore.py:1550 DEBUG Worker
> > 0 starting
> > 09/12/05 14:53:09 2440 DataStore datastore.py:1544 DEBUG
> > Waiting thread 0
> > 09/12/05 14:53:09 2440 DataStore datastore.py:1547 DEBUG Done
> > creating workers
> > 09/12/05 14:53:09 2440 DataStore datastore.py:278 DEBUG Reading
> > persisted data from: C:\Documents and Settings\Dio\Application Data
> > \AccessGrid\Config\personalDataStore\DataStore.dat
> > 09/12/05 14:53:09 2440 VenueClient venueclient.py:210 DEBUG
> > __createPersonalDataStore: Load personal data from file
> > 09/12/05 14:53:09 2440 VenueClientController
> > venueclientcontroller.py:1255 DEBUG There is no personal venues
> > file to load.
> > 09/12/05 14:53:12 2440 VenueClient venueclient.py:809 DEBUG
> > EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> > 09/12/05 14:53:12 2440 VenueClient venueclient.py:836 INFO
> > EnterVenue: Error getting node capabilities
> > 09/12/05 14:53:12 2440 VenueClient venueclient.py:705 DEBUG
> > EnterVenue: Invoke venue enter
> > 09/12/05 14:53:12 2440 VenueClient venueclient.py:869 ERROR
> > EnterVenue: failed
> > line 840, in EnterVenue
> > self.__EnterVenue(URL)
> > line 706, in __EnterVenue
> > (venueState, self.privateId, self.streamDescList ) =
> > self.__venueProxy.Enter( self.profile )
> > File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line
> > 3492, in Enter
> > (r1, r2, r3) = self.proxy.Enter(profile)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453,
> > in __call__
> > return self.__r_call(*args, **kw)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475,
> > in __r_call
> > self.__hd, self.__ma)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338,
> > in __call
> > config = self.config, noroot = self.noroot)
> > File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line
> > 620, in buildSOAP
> > return t.build()
> > 118, in build
> > body_ns = self.genns(ns_map, NS.ENV)[0]
> > 204, in genns
> > if type(nsURI) == TupleType: # already a tuple
> > NameError: global name 'TupleType' is not defined
> > 09/12/05 14:53:12 2440 VenueClient venueclientui.py:1925 DEBUG
> > bin.VenueClient::EnterVenue: Enter venue with url: https://
> > 09/12/05 14:53:12 2440 VenueClient venueclientui.py:1938 DEBUG
> > warningString:
> > 09/12/05 14:53:14 2440 VenueClient venueclientui.py:1565 INFO
> > --------- END VenueClient
> > 09/12/05 14:53:14 2440 DataStore datastore.py:1614 DEBUG
> > Quitting thread 0
> > 09/12/05 14:53:14 2540 DataStore datastore.py:1555 DEBUG Worker
> > 0 gets cmd quit
> > 09/12/05 14:53:14 2540 DataStore datastore.py:1568 DEBUG Worker
> > 0 exiting
> > 09/12/05 14:53:14 2440 NodeService agnodeservice.py:135 INFO
> > NodeService.Stop
> > 09/12/05 14:53:14 2440 ServiceManager agservicemanager.py:84
> > INFO AGServiceManager.Shutdown
> > 09/12/05 14:53:14 2440 ServiceManager agservicemanager.py:85
> > INFO Remove services
> > 09/12/05 14:53:14 2440 ServiceManager agservicemanager.py:389
> > INFO AGServiceManager.RemoveServices
> > 09/12/05 14:53:14 2544 DataStore datastore.py:1627 INFO
> > GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation,
> > most likely shutting down.
> > 09/12/05 14:53:14 2440 ServiceManager agservicemanager.py:87
> > INFO Stop network interface
> > 09/12/05 14:53:14 3196 Hosting server.py:65 ERROR Exception in
> > SOAP server main loop
> > File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy
> > \Server.py", line 63, in Run
> > self._server.handle_request()
> > File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
> > request, client_address = self.get_request()
> > File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line
> > 140, in get_request
> > sock, addr = ThreadingGSITCPSocketServer.get_request(self)
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> > get_request
> > self.socket.listen()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in
> > listen
> > raise ex
> > GSITCPSocketException: an I/O operation was cancelled
> > 09/12/05 14:53:14 2440 Hosting server.py:97 ERROR server_close
> > () failed
> > \Server.py", line 95, in Stop
> > self._server.server_close()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043,
> > in server_close
> > self.socket.close()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020,
> > in close
> > IOBase.close(self)
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in
> > close
> > raise ex
> > IOBaseException: an uninitialied data structure was passed as
> > argument 1 to globus_io_register_close
> > () failed
> > in server_close
> > self.socket.close()
> > in close
> > IOBase.close(self)
> > close
> > raise ex
> > <dioselin.vcf>
