[AG-TECH] Node Service Fails
Christoph Willing
willing at itee.uq.edu.au
Thu Oct 20 20:22:09 CDT 2005
On 21/10/2005, at 8:57 AM, Gregory Browning wrote:
> Hello all,
> I am having a problem that is driving me crazy. Here is my
> setup:
> 3 machines, 1 windows xp (display), 2 Fedora core 3 (video and
> audio) running AGTK 2.3.
> Ok, We have had this setup for about a year now and everything has
> worked ok until a month ago.
> Here is what I do to start my access grid.
> Start agservicemanager.py on the video machine. (starts no problem)
> Start agservicemanager.py on the audio machine. (starts no problem)
> Start the node service on the display machine. (errors out)
> Here is the error:
[snip]
> Exception: Failed to load default configuration <FINAL1>
Greg,
There should be a file:
C:\Documents and Settings\your username\Application Data
\AccessGrid\Config\nodeConfig\defaultWindows
Check that its there and readable (its just a text file). It may have
become corrupted or lost.
If necessary, you could copy it there manually from its original
location at:
C:\Program Files\AGTk-2.3\config\nodeConfig\defaultWindows
(which would result in loss of any prior configuration you had set up)
chris
Christoph Willing +61 7 3365 8350
QPSF Access Grid Manager
University of Queensland
