[AG-TECH] Winnov Videum 4400 VO
    Derek Piper
    dcpiper at indiana.edu
    Wed Oct 19 16:27:55 CDT 2005
	To interject, what chips does the Winnov Videum 4400 use? I didn't see
it on the website. I have a Spectra8 card (4 BT878 chips) that I'd love
to have VFW drivers for. For the same reason, so the video sources would
be able to come up automatically on the windows machine its installed
in, instead of the input selection 'ritual' you have to go through when
entering a venue. For me, it's not so much they start on the same input,
all VICs try and only one succeeds, leaving others with a selection
dialog to sort it out. If I select a previously used input, vic crashes.
	Derek
Thomas D. Uram wrote:
> Doug:
> Can you specify which version of the software you're using, which
> drivers you have installed (vfw or wdm)?  If you're using 2.3 with the
> service updates installed, or 2.4, I'd be interested in seeing your
> VideoProducerService.log file (by private mail).
> Tom
> On 10/19/05 2:56 PM, Douglas Baggett wrote:
>> I have pretty much the same problem. Starting up the AG causes 3
>> identical windows to start up on one input. Changing the input has no
>> effect. I'd love to be able to use AG2.x with the Videum card InSors
>> installed.
>> -Doug B
>> CISE/OAD/NSF
>> Rosario Lombardo wrote:
>>> Just reporting my experience:
>>> I had the problems described by Andy which were solved after
>>> installing the driver reported below:
>>> - VFW drivers
>>> ftp://64.62.227.4/drivers/Videum_3_1_Release_NT_W2K_XP.exe found on
>>> winnov.com
>>> - AGtk2.4
>>> - IG2
>>> Whichever client is started first, takes over the *two* cameras
>>> connected.
>>> \\Rosario
>>>> Yes you do; the AG vic does not support the use of WDM drivers,
>>>> unfortunately.  If anyone has cycles to spend on this, it'd be a big
>>>> help to the AG community.
>>>> Tom
>>>> On 10/19/05 10:02 AM, A Quay wrote:
>>>>> Do I have to use the VFW drivers with the Videum 4400 to transmit four
>>>>> cameras in AG 2.4?
>>>>> Using VFW drivers instead of WDM is a problem since the same
>>>>> computer is
>>>>> used with our inSORS grid software.
>>>>> Andy Quay
>>>>> University of Florida
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
