[AG-TECH] Winnov Videum 4400 VO
    Douglas Baggett
    dbaggett at cise-nsf.gov
    Wed Oct 19 14:56:26 CDT 2005
I have pretty much the same problem. Starting up the AG causes 3
identical windows to start up on one input. Changing the input has no
effect. I'd love to be able to use AG2.x with the Videum card InSors
installed.
-Doug B
CISE/OAD/NSF
Rosario Lombardo wrote:
> Just reporting my experience:
> I had the problems described by Andy which were solved after
> installing the driver reported below:
> - VFW drivers
> ftp://64.62.227.4/drivers/Videum_3_1_Release_NT_W2K_XP.exe found on
> winnov.com
> - AGtk2.4
> - IG2
> Whichever client is started first, takes over the *two* cameras
> connected.
> \\Rosario
> Thomas D. Uram wrote:
>> Yes you do; the AG vic does not support the use of WDM drivers,
>> unfortunately.  If anyone has cycles to spend on this, it'd be a big
>> help to the AG community.
>> Tom
>> On 10/19/05 10:02 AM, A Quay wrote:
>>> Do I have to use the VFW drivers with the Videum 4400 to transmit four
>>> cameras in AG 2.4?
>>> Using VFW drivers instead of WDM is a problem since the same
>>> computer is
>>> used with our inSORS grid software.
>>> Andy Quay
>>> University of Florida
