[AG-TECH] RAT volume slider problem
Matthew Rendell
matthew.rendell at flinders.edu.au
Wed Nov 30 15:39:19 CST 2005
We have a similar problem on our Windows XP Access Grid
It seems to happen when service pack 2 (?) is rolled out... The talk and
listen buttons used to work independantly but now it seems that when you
turn of the talk, the listen drops out approx 2 seconds later... It also
seems that even with the talk level down to 0, the mics still transmit..
This may have been caused by the rebuilding of the audio computer onto a
different motherboard (as the other one failed) and I will see if it
still happens when we rebuild it with the original spec mobo..
Thanks
Matthew Rendell
Technical Theatre Support - Access Grid Operator
Theatre Support, Information Services Division
Flinders University, Adelaide SA
Phone: 08 8201 5728
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20051201/bf409ac1/attachment.htm>
