[AG-TECH] Firewall ports
Julia Mullen
julia.mullen at gmail.com
Tue Nov 29 10:50:34 CST 2005
Hi David,
If you are using the NCSA venues, you can check these at:
http://agachedule.ncsa.uiuc.edu/venues.asp
where there is a list of venues, with ports for multicast as well as
bridge information with ports for unicast.
Good luck.
Julie
On 11/29/05, West, David F. <dfwest at st-aug.edu> wrote:
> I might be missing the obvious but did not find any documentation on
> Access Grid port# usage for Unicast and Multicast. Problem is we can
> transmit but not receive inbound. Know the equipment is good since I can
> use it offsite with out problem.
> Does any one know the required inbound and outbound ports for Unicast
> and Multicast under the AG?
> Thank you for any information!
> David West
> Saint Augustine's College
