[AG-TECH] AGVCR file format
monika.k.rabarison at ccaix.jsums.edu
Fri Nov 11 10:52:32 CST 2005
No problem for me, Derek. So, I did the recordings fur
testing purpose only.
-Monika
> Hi all,
> I had a thought yesterday that possibly I should make
> some changes to allow AGVCR to support, at least in the
> file format for now, any number of RTP/RTCP streams
> per-recording. Now, I know it's only been out for a
> couple of days and only people on this list know about it,
> so I was thinking that if I make those changes - would it
> matter if it broke any recordings anyone has made at this
> point? I can try and get the converter program working
> correctly if anyone's recorded anything in the last
> couple of days they absolutely cannot live without. I have
> recordings of my own that are nearly able to be converted
> perfectly from even older formats I had, so the converter
> will be around eventually.
> I know I said I wouldn't change the file format, but
> given the responses I've had, it seems that supporting
> anything from 1 stream or more would be a useful change
> to make at this point, i.e. before too many recordings
> get made. Adding on different types of streams to record
> and interface changes can come later but then will be
> compatible with recordings made in the new format.
> I probably should look at setting up some sort of
> mailing list for this program so I'm not hijacking the
> ag-tech list to discuss it :) So, thanks ANL :)
> Anyway, I thought I'd throw that out there in case
> anyone had any such recording they have to keep, anything
> to mention, or ideas they want to see incorporated. Feel
> free to contact me off-list if you'd prefer.
> Thanks,
> Derek
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
