[AG-TECH] Video Capture Card Misery
Ben Ware
bware at utk.edu
Thu Nov 3 12:39:31 CST 2005
I believe we use 4 of the WinTV cards in our XP SP2 machine, but it did
take some work to get it going. We actually had to use a different
driver for them, no Hauppauge driver did the trick, so we are using the
BtPCI WDM driver, which I found on Google. If memory serves, you
install this and then actually pick which of many cards you have from a
list. The only snag we have now that this is installed is that when you
enter a venue and have more than one video source you are trying to
send, you have to go to that machine and manually select each card to
match up with each service each time, because for some reason the
service trys to just pull all video inputs from the same card until you
tell it otherwise. Until you do that each time, it simply sends one
video input.
I do also remember that we could only have one of the WinTV cards
installed into a slightly older machine, still running XP SP2. For some
reason if I put more than 1 in, it gave me resource conflicts even
though I had free resources.
But since you can't get even one card to work, from the sounds of it,
then I would try using the above driver. If you need me to, I think I
saved it and I could send it to you later on this afternoon.
I hope that helps - Ben
Nagykaldi, Zsolt F. (HSC) wrote:
> Anybody, ever installed a Hauppauge WinTV video capture card on a
> WinXP Pro SP2 that actually WORKED with the AG Venue client??? I have
> spent days with this thing and I am desperate here. What other cards
> do you have for this particular setup that works for you?
> THANKS.
> _ _ _
> Zsolt Nagykaldi, PhD
> Research Associate, Clinical IT Specialist
> University Of Oklahoma Health Sciences Center
> Department Of Family And Preventive Medicine
> Oklahoma Center For Family Medicine Research
> 900 NE 10th Street
> Oklahoma City, OK 73104
> Phone: (405) 271-8000 Ext.:1-32212
> Fax: (405) 271-1682
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20051103/7364ff55/attachment.htm>
