[AG-TECH] Geowall / Agave help
    Anibal Vega-Montijo
    avega at rcm.upr.edu
    Wed Nov  2 09:49:12 CST 2005
Hi Martin;
Thanks for the information in the projects at Manchester.
I think that you can try DVTS to transmit the two videos from the Sony
camcorders to get a better video quality but using 60Mbps.
Anibal
Martin Turner wrote:
>Just an aside.
>At Manchester Computing we are great fans of both GeoWalls (for 3D stereoscopic visualization) and the AG. Like having a GeoWall as portable as possible for remote use [luggable unit];
>A couple of projects and installations that may interest:
>1. We can now transmit the TGS/amira scientific visualization software output from the rendering screen - as two vic streams - that can be received by the GeoWall via AG. Picture at the bottom of the page shows the setup.
>http://www.sve.man.ac.uk/mvc/Research/rvamira/
>2. We are constructing a stereoscopic recording system - using two Sony camcorders connected to the GeoWall shuttle - these can record and simultaneously transmit as two vic streams or as a single anglyph (okay quality is not great due to the cross coding of colours within the vic coder) vic stream.
>A picture from the UK e-Science all hands stand, and some blurb:
>http://www.sve.man.ac.uk/mvc/Research/sage/
>3. Finally if you can persuade your local AG room - it is possible to construct a fixed dual use stereoscopic and AG room. Within the e-Science centre at Manchester Computing; Room 1:10 combines both facilities.
>We have effectively a cluster of three GeoWalls - switched with a normal four screen AG node; that use the Geowall projectors. This way you can have one third of the space (about a 7mx2m screen) a GeoWall can run and the other two-thirds as normal 2D AG screens etc.
>Missing a website with pictures - will set one up.
>This system was installed as separate units to help users but using them together is not that tricky - although we run separate Access Grid software on each of the (four!) machines [actually we have never run everything at once].
>And a bit of advertisement as you will see some of this at this years SC Global event:
>Tuesday 15th November:
>1:30PM - 2:10PM 		SC Global Showcase 		Collaborative Virtual Reality 		Augmented Stereoscopic Codecs over the Access Grid Environment 		Anja Le Blanc, Martin John Turner 		618-620
>Yours Martin Turner
>Aside - For fun; it is possible to run two instances of powerpoint; one for each eye at the same time - although no easy way to change slide slickly. So stereoscopic powerpoint.
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Tom Coffin
>Sent: 01 November 2005 21:10
>To: Anibal Vega-Montijo; ag-tech at mcs.anl.gov
>Subject: Re: [AG-TECH] Geowall / Agave help
>What we do at ACCESS is the place the display of the Geowall
>adjacent to the display of the AccessGrid - There are
>experimental applications which can be initiated by icons
>in the venue client of the Accessgrid - still you will
>want the displays adjacent to each other to enable the
>applications of video, audio and the visualization.
>_________________________________________________
>At 12:29 PM 11/1/2005, Anibal Vega-Montijo wrote:
>>Hi,
>>I am Anibal Vega-Montijo from the University of Puerto Rico Medical
>>Sciences Campus. We are in the process of building an AG node. We also
>>bought the equipment Agave/Geowall. How can we integrate AG with Geowall?
>>We are in a medical research enviroment so we like to have a collaborative
>>3d enviroment to view molecules, proteins, etc.
>>Anibal
>>Anibal Vega-Montijo (avega at rcm.upr.edu)
>>Systems Programmer
>>Center for Information Architecture in Research
>>Research Centers in Minority Institutions
>>University of Puerto Rico Medical Sciences Campus
>>(787) 758-2525 ext 2193
>___________________________________________________________
>Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
>    NCSA-ACCESS                         cel: 703-477-5948
>    901 North Stuart Street, #800       tel: 703-248-0105
>    Arlington, Virginia 22203           fax: 703-248-0100
>_________________________ http://www.ncsa.uiuc.edu/~tcoffin
Systems Programmer
