[AG-TECH] AccessGrid 3: What information is available
Ivan R.Judson
judson at mcs.anl.gov
Tue May 24 09:45:58 CDT 2005
I believe (from what I've seen) the move away from GSITCP increases
performance *HUGELY*; it's an entirely different system
performance-wise.
configuration mgmt is something I know has been talked about, but I'll
let Tom or someone else from the Team answer.
--Ivan
On May 24, 2005, at 9:38 AM, Derek Piper wrote:
> While we're on the subject of globus and stuff like that, will we
> still have to wait days in order to get a node up and running because
> of getting the certificates? It's one of the most tiresome things
> about setting up a new node.
> Also, something I'd REALLY like to see is the ability to set a
> site-wide configuration under Linux and Windows. Sure have the users
> have a .AccessGrid folder (or the equivalent under 'Documents and
> Settings' for Windows) but having a system-wide config would be VERY
> advantagous to me in setting up conference room AG nodes. Then, a user
> known to the network can log in and it's already set up with the same
> config everyone else uses. I don't like having to have just one user
> run the AG stuff, especially with shared apps and the possibility that
> new users want to get on the AG for a meeting, share their stuff in a
> conference and get off. It would be nice if they could use a site
> conference room and fairly much do it themselves, albeit with a
> modicum of training.
> Derek
> John Hodrien wrote:
>> On Tue, 24 May 2005, Ivan R.Judson wrote:
>>> Hey John,
>>> Good point. Although my skepticism keeps nagging with the worry,
>>> "Why bother
>>> with WSRF/GT4 services, aren't Web Services good enough?" I suspect
>>> they
>>> are, I haven't seen any significant value to the layers above that
>>> provided
>>> by GT4.
>> If you try and ignore the globus stuff, and think of it as WSRF it
>> becomes
>> more pleasant. GT4 contains lots of crap for submitting jobs and
>> managing
>> resources, copying files about etc. I have no immediate interest in
>> any of
>> that. WSRF is the OASIS working draft for stateful web services, and
>> as such
>> is intended to be something nice and generic, usable whenever you
>> want state
>> in a web service.
>> The most important part of it as I'm concerned (if you were
>> entertaining the
>> notion of AG with web services) would be WS-Resource and
>> WS-Notifications.
>> http://docs.oasis-open.org/wsrf/2005/03/wsrf-WS-Resource-1.2-draft
>> -03.pdf
>> http://docs.oasis-open.org/wsn/2004/06/wsn-WS-BaseNotification-1.2-
>> draft-03.pdf Sadly you can quickly complicate things, as you're
>> likely to need
>> WS-Reliability if you're going down the notifications road.
>> http://www.oasis-open.org/committees/tc_home.php?wg_abbrev=wsrm
>> I'm not sure what else would be worth poking at, bits like
>> WS-ResourceLifetime
>> might also deserve a look in.
>> Equally, playing with WS-Security and using the SAML callout would
>> let you
>> define whatever you wanted on the security front, and make it open and
>> standardised how you were doing it.
>> These are all boxes of tricks that live independently of GT4
>> (WSRF.NET for
>> example) but would open up the AG to open and standard interaction
>> with other
>> software.
>> So really my case for this isn't in favour of GT4, it's in favour of
>> standardised (very nearly at least ;) stateful web services.
>>> Did I miss something :-)?
>> I'm sure we've all missed plenty ;)
>> jh
> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> IRI 323, School of Informatics
> Indiana University, Bloomington, Indiana
