[AG-TECH] VenueIW
    Susanne Lefvert
    lefvert at mcs.anl.gov
    Fri May 20 10:54:37 CDT 2005
It is not the VenueIW call that fails it is the self.currentVenue.Enter()
call. If you look in the API the enter call should include a client profile:
Enter(self, profile)
Susanne
On Fri, 20 May 2005 mimiller at ncsa.uiuc.edu wrote:
> I was using the example listed here:
> http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/developer/examples/GetClients.py
> To try to create a Venue object thus:
>      def ChangeCurrentVenue(self, venuedesc = None):
>          if venuedesc == None:
>              if self.isInVenue:
>                  self.currentvenue.Exit()
>          else:
>              self.currentvenue = VenueIW(venuedesc.GetURI())
>              self.currentvenue.Enter()
>              self.isInVenue=1
> and I get the following error
> VenueManagement.py", line 920, in ChangeCurrentVenue
> TypeError: Enter() takes exactly 2 arguments (1 given)
> So I looked at the VenueIW API which states:
> __init__(self, url, faultHandler)
> In the example at the link above all I had to do was this:
> venue = VenueIW(url)
> I've got a basic idea of what the faultHandler should do, but I'm not sure
> what it should be, an object? a string? a callback function?
> I can't seem to find any other examples of using the VenueIW
> interface.  Why does it work with the example and not with my code?
> Thanx,
> Michael Miller
> System Engineer
> Video Technology Services
> Persistent Infrastructure Directorate
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve everything
> desired, and usually deliver everything you could have hoped for and even
> more." -Paul Debevec
