[AG-TECH] Can't connect to RCBridge
Natalia Costas Lago
natalia at cesga.es
Wed May 18 10:02:01 CDT 2005
Yeah, that's right, I'm running 2.6. I really appreciate if you could send
me the updated version.
Thanx a lot.
Kind regards,
Natalia.
----- Original Message -----
From: "Markus Buchhorn" <Markus.Buchhorn at anu.edu.au>
To: "Natalia Costas Lago" <natalia at cesga.es>; "ag-tech"
<ag-tech at mcs.anl.gov>
Cc: <rod.harris at anu.edu.au>
Sent: Tuesday, May 17, 2005 6:23 AM
Subject: Re: [AG-TECH] Can't connect to RCBridge
> Hi Natalia
> At 08:06 PM 16/05/2005 +0200, Natalia Costas Lago wrote:
>>I've read about RCBridge and it seems quite an interesting tool (mainly
>>because the last 2h sesion we recorded was 2 GB in size, so some kind of
>>streams selection method is needed).
> Our recording system has stream selection too :-) for that very reason.
>>I installed the software (java and so).. and i can connect from a client
>>by means of a web browser, but problems arise when the bridge is to be
>>created:
>>UdpListener error: Failed to create socket: Cannot assign requested
>>address: 239.194.100.100/1234
>>UdpBridge Error: Couldn't create UdpBridge from /239.194.100.100:1234 to
>>/193.144.36.152:17306
>>Client: couldn't make Rtp/Rtcp Bridges
> Ah, you're probably on a 2.6 kernel system. Sorry - there's an updated
> version I can point you to which fixes this, but I'm out of the office
> right at the moment - Rod, can you please point Natalia to it? (I need to
> update the rcbridge webpage, <sigh> and the rest)
> Cheers,
> Markus
> Markus Buchhorn, ANU Internet Futures |Ph: +61 2 61258810
> Markus.Buchhorn at anu.edu.au |Fx: +61 2 61259805
> The Australian National University, Canberra 0200 |Mob: 0417 281429
