[AG-TECH] machine freezes on rat start up OSC
Donald Roeber
droeber at isc.upenn.edu
Tue May 10 10:43:13 CDT 2005
Crazy. Since upgrading to 10.4, VIC now works for me, which it
never did under 10.3.x.
When you upgraded to Tiger, how did you do it? I did an Archive and
Install, and chose X11 as an additional component to install (it
wasn't listed to be installed by default). I'm using a PowerMac G5
dual 2.5GHz and a PowerBook G4 1GHz 12".
On May 10, 2005, at 10:59 AM, John I Quebedeaux Jr wrote:
> Hi Paul,
> With Tiger 10.4 I also get a hard freeze when starting up the
> toolkit. I haven't had time to try to figure out what/why/when/
> where it is though.
> Interesting through that with 10.3.9 and 10.4 we get freezes. I
> don't even get to the rat though.
> When I say freeze... i mean freeze. Lockup hard. I have to hold
> down the power key to reset the machine. Someone else in my dept.
> reports the same thing.
> -JQ
> John I. Quebedeaux, Jr.
> Louisiana State University
> Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339
> Johnston Hall
> e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://
> lbrn.lsu.edu & http://cct.lsu.edu
> phone: 225-578-0062 / fax: 225-578-2597
> On May 9, 2005, at 7:23 PM, Paul Mercer wrote:
>> All
>> After installing the Apple Security Update 2005-05 for 10.3.9, my
>> machine now freezes when rat starts. An X11 window opens, as
>> usual, and then a short while later my machine freezes requiring a
>> restart.
>> Has anyone else experienced this?
>> I also installed the following updates at the same time.
>> Java Update for 10.3.9
>> Quicktime 7.0
>> Remote Desktop Admin. 2.2
>> X11 fixes in update:
>> # libXpm
>> CVE ID: CAN-2004-0687 CERT: VU#882750
>> Available for: Mac OS X v10.3.9, Mac OS X Server v10.3.9
>> Impact: A vulnerability in the parsing of malformed XPM files could
>> allow arbitrary code execution
>> Description: The xpmParseColors() function in the XFree86 libXpm
>> library contains a vulnerability in the parsing of malformed image
>> files that may lead to a stack overflow and could allow arbitrary
>> code execution. Images downloaded via a web browser may use the XPM
>> format and allow remote exploitability. libXpm is not installed by
>> default on Mac OS X or Mac OS X Server systems. It is an optional
>> install item via the X11 package. Credit to Chris Evans
>> <chris at scary.beasts.org> for reporting this issue.
>> # libXpm
>> CVE ID: CAN-2004-0688 CERT: VU#537878
>> Description: Multiple libXpm routines contain integer overflow
>> vulnerabilities that may allow an attacker to cause a
>> denial-of-service condition or execute arbitrary code. Images
>> downloaded via a web browser may use the XPM format and allow remote
>> exploitability. libXpm is not installed by default on Mac OS X or
>> Mac OS X Server systems. It is an optional install item via the X11
>> package. Credit to Chris Evans <chris at scary.beasts.org> for
>> Any help will be appreciated.
>> Thanks
>> Paul
>> Paul Mercer
>> Arctic Region Supercomputing Center
>> 907 450 8649
Donald Roeber
ISC Networking
