[AG-TECH] machine freezes on rat start up OSC
Paul Mercer
mercer at arsc.edu
Mon May 9 19:23:58 CDT 2005
All
After installing the Apple Security Update 2005-05 for 10.3.9, my
machine now freezes when rat starts. An X11 window opens, as usual,
and then a short while later my machine freezes requiring a restart.
Has anyone else experienced this?
I also installed the following updates at the same time.
Java Update for 10.3.9
Quicktime 7.0
Remote Desktop Admin. 2.2
X11 fixes in update:
# libXpm
CVE ID: CAN-2004-0687 CERT: VU#882750
Available for: Mac OS X v10.3.9, Mac OS X Server v10.3.9
Impact: A vulnerability in the parsing of malformed XPM files could
allow arbitrary code execution
Description: The xpmParseColors() function in the XFree86 libXpm
library contains a vulnerability in the parsing of malformed image
files that may lead to a stack overflow and could allow arbitrary
code execution. Images downloaded via a web browser may use the XPM
format and allow remote exploitability. libXpm is not installed by
default on Mac OS X or Mac OS X Server systems. It is an optional
install item via the X11 package. Credit to Chris Evans
<chris at scary.beasts.org> for reporting this issue.
# libXpm
CVE ID: CAN-2004-0688 CERT: VU#537878
Description: Multiple libXpm routines contain integer overflow
vulnerabilities that may allow an attacker to cause a
denial-of-service condition or execute arbitrary code. Images
downloaded via a web browser may use the XPM format and allow remote
exploitability. libXpm is not installed by default on Mac OS X or
Mac OS X Server systems. It is an optional install item via the X11
package. Credit to Chris Evans <chris at scary.beasts.org> for
Any help will be appreciated.
Thanks
Paul
Paul Mercer
Arctic Region Supercomputing Center
907 450 8649
