[AG-TECH] Problem with BridgeServer
Thomas D. Uram
turam at mcs.anl.gov
Mon Mar 28 12:53:57 CST 2005
Hi Brian:
It looks like you're doing everything right. The error message from Rat indicates (as far
as I can tell) that it can't resolve pcdiag11. This could be fixed for machines on your
local net by adding an entry for pcdiag11 to DNS. A more general solution would be to
modify pcdiag11:/etc/hosts to include the fqdn of the host:
127.0.0.1 localhost pcdiag11.xor.aps.anl.gov
This points out a problem with the BridgeServer that we'll have to address.
Let me know if the problem persists.
Tom
Brian Tieman wrote:
> Hi all,
> I'm trying to set up a bridge server and I'm getting an error in RAT.
> The error is "Invalid address:pcdiag11/30008". pcdiag11 is the venue
> server machine. I have included the config file for the BridgeServer as
> well as it's log file and output.
> I don't see anything obvious--but then I don't really knew what I'm
> doing either ;)
> Thanks all!
> Brian
> [BridgeServer]
> name=2BM
> location=APS
> qbexec=/usr/bin/QuickBridge
> portMin=30000
> portMax=30010
> [https://pcdiag11.xor.aps.anl.gov:8000/VenueServer]
> type=VenueServer
> portMin=30000
> portMax=30010
> 03/18/05 09:58:57 -151080192 ProxyGen __init__.py:988 DEBUG Using GT24 proxy code
> 03/18/05 09:58:58 -151080192 Toolkit __init__.py:988 DEBUG Initializing AG Toolkit version 2.3
> 03/18/05 09:58:58 -151080192 Toolkit __init__.py:988 INFO Logfile Name: BridgeServer.log
> 03/18/05 09:58:59 -151080192 Toolkit __init__.py:988 INFO Service init: have profile None
> 03/18/05 09:58:59 -151080192 Platform __init__.py:988 DEBUG retrieved local IP address 164.54.100.13
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG Opened repository /aguser/.AccessGrid/Config/certRepo
> 03/18/05 09:58:59 -151080192 Toolkit __init__.py:988 INFO Initialized cert mgmt.
> 03/18/05 09:58:59 -151080192 Toolkit __init__.py:988 INFO Loaded profile and configured with it.
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG Configuring standard environment
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=aps.anl.gov/CN=Brian Tieman
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=aps.anl.gov/CN=Brian Tieman
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG Looking for identity (unused) None
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=aps.anl.gov/CN=Brian Tieman
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG Proxy /tmp/x509up_u501 will expire 03/22/05 10:05:55
> 03/18/05 09:58:59 -151080192 CertificateManager __init__.py:988 DEBUG done, success=1
> 03/18/05 09:58:59 -151080192 Toolkit __init__.py:988 INFO Initialized Globus.
> 03/18/05 09:58:59 -151080192 Toolkit __init__.py:988 INFO Service Initialization Complete.
> 03/18/05 09:58:59 -151080192 Toolkit __init__.py:988 INFO AddVenueServer: url = https://pcdiag11.xor.aps.anl.gov:8000/VenueServer
> 03/18/05 09:58:59 -151080192 Toolkit __init__.py:988 DEBUG Initializing AG Toolkit version 2.3
> 03/18/05 09:59:05 -151080192 Toolkit __init__.py:988 INFO AddVenue: url = https://164.54.100.13:8000/Venues/0000010216f41e4b00a400360064000d967
> 03/18/05 09:59:19 -151080192 EventClient __init__.py:988 DEBUG Have callback handle _78aa9409_p_callbackStruct
> 03/18/05 09:59:30 -151080192 Toolkit __init__.py:988 INFO AddVenue: url = https://164.54.100.13:8000/Venues/000001025fe422fe00a400360064000d30b
> 03/18/05 09:59:30 -211141712 Toolkit __init__.py:988 INFO Method Venue.RunQueueThread called
> 03/18/05 09:59:56 -151080192 EventClient __init__.py:988 DEBUG Have callback handle _00568f09_p_callbackStruct
> 03/18/05 10:00:04 -151080192 Toolkit __init__.py:988 INFO AddVenue: url = https://164.54.100.13:8000/Venues/000001025fe4f27c00a400360064000dfa4
> 03/18/05 10:00:04 -242611280 Toolkit __init__.py:988 INFO Method Venue.RunQueueThread called
> 03/18/05 10:00:33 -151080192 EventClient __init__.py:988 DEBUG Have callback handle _80e69809_p_callbackStruct
> 03/18/05 10:00:45 -151080192 Toolkit __init__.py:988 INFO AddVenue: url = https://164.54.100.13:8000/Venues/000001025fe5645700a400360064000db90
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO Method Venue.RunQueueThread called
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO Method Venue.AddBridge called
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO Method CreateBridge called
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO Allocated port = 30002
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO - creating new bridge
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO Method Bridge.Start called
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO Starting bridge:
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO [maddr,mport,mttl] = 224.2.150.90 52847 127
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO [uaddr,uport] = pcdiag11 30002
> 03/18/05 10:00:45 -274080848 Toolkit __init__.py:988 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.150.90', '-m', '52847', '-u', '30002']
> 03/18/05 10:00:58 -158688336 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f84f9d09_p_globus_io_handle_t result=(0, None) n=4
> 03/18/05 10:00:58 -158688336 EventClient __init__.py:988 DEBUG Freeing callback _80e69809_p_callbackStruct within callback
> 03/18/05 10:00:58 -158688336 EventClient __init__.py:988 DEBUG Have new callback handle _80e69809_p_callbackStruct
> 03/18/05 10:00:58 -158688336 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f84f9d09_p_globus_io_handle_t result=(0, None) n=1209
> 03/18/05 10:00:58 -158688336 EventClient __init__.py:988 DEBUG finally read enough data, wait=1209 buflen=1209
> 03/18/05 10:00:58 -158688336 EventClient __init__.py:988 DEBUG handleData returns
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO Method Venue.AddBridge called
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO Method CreateBridge called
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO Allocated port = 30008
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO - creating new bridge
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO Method Bridge.Start called
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO Starting bridge:
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO [maddr,mport,mttl] = 224.2.133.108 56389 127
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO [uaddr,uport] = pcdiag11 30008
> 03/18/05 10:01:02 -274080848 Toolkit __init__.py:988 INFO Starting bridge: /usr/bin/QuickBridge ['-g', '224.2.133.108', '-m', '56389', '-u', '30008']
> 03/18/05 10:01:13 -158688336 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f84f9d09_p_globus_io_handle_t result=(0, None) n=4
> 03/18/05 10:01:13 -158688336 EventClient __init__.py:988 DEBUG Freeing callback _80e69809_p_callbackStruct within callback
> 03/18/05 10:01:13 -158688336 EventClient __init__.py:988 DEBUG Have new callback handle _80e69809_p_callbackStruct
> 03/18/05 10:01:13 -158688336 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f84f9d09_p_globus_io_handle_t result=(0, None) n=1210
> 03/18/05 10:01:13 -158688336 EventClient __init__.py:988 DEBUG finally read enough data, wait=1210 buflen=1210
> 03/18/05 10:01:13 -158688336 EventClient __init__.py:988 DEBUG handleData returns
> 03/18/05 10:01:31 -151080192 EventClient __init__.py:988 DEBUG Have callback handle _40dd9809_p_callbackStruct
> 03/18/05 10:01:42 -305550416 Toolkit __init__.py:988 INFO Method Venue.RunQueueThread called
> 03/18/05 10:07:36 -151080192 Toolkit __init__.py:988 INFO Method BridgeServer.Shutdown called
> 03/18/05 10:07:36 -151080192 Toolkit __init__.py:988 INFO Method BridgeServer.RemoveVenues called
> 03/18/05 10:07:36 -151080192 Toolkit __init__.py:988 INFO Method Venue.Shutdown called
> 03/18/05 10:07:36 -151080192 Toolkit __init__.py:988 INFO - Send stop message to bridges
> 03/18/05 10:07:36 -151080192 Toolkit __init__.py:988 INFO - Stopping event client
> 03/18/05 10:07:36 -151080192 EventClient __init__.py:988 DEBUG Cancel pending callbacks
> 03/18/05 10:07:36 -158688336 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_68bf9d09_p_globus_io_handle_t result=(48, 'an I/O operation was cancelled') n=0
> 03/18/05 10:07:36 -158688336 EventClient __init__.py:988 DEBUG readCallback gets failure in result: 48 an I/O operation was cancelled
> 03/18/05 10:07:37 -253101136 Toolkit __init__.py:988 INFO Heartbeat thread exiting (1)
> 03/18/05 10:07:37 -151080192 EventClient __init__.py:988 DEBUG Free callback _00568f09_p_callbackStruct
> 03/18/05 10:07:37 -151080192 EventClient __init__.py:988 DEBUG EventClient.Stop: closing socket
> 03/18/05 10:07:37 -151080192 EventClient __init__.py:988 DEBUG EventClient.Stop: closing queue
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO - Wait for bridges to shutdown
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO - Send stop message to queue processor
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO Shutdown exiting
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO Method Venue.Shutdown called
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO - Send stop message to bridges
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO - Stopping event client
> 03/18/05 10:07:37 -151080192 EventClient __init__.py:988 DEBUG Cancel pending callbacks
> 03/18/05 10:07:37 -242611280 Toolkit __init__.py:988 INFO RunQueueThread exiting
> 03/18/05 10:07:37 -190162000 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_489b8d09_p_globus_io_handle_t result=(50, 'an I/O operation was cancelled') n=0
> 03/18/05 10:07:37 -190162000 EventClient __init__.py:988 DEBUG readCallback gets failure in result: 50 an I/O operation was cancelled
> 03/18/05 10:07:37 -151080192 EventClient __init__.py:988 DEBUG Free callback _78aa9409_p_callbackStruct
> 03/18/05 10:07:37 -211141712 Toolkit __init__.py:988 INFO RunQueueThread exiting
> 03/18/05 10:07:37 -221631568 Toolkit __init__.py:988 INFO Heartbeat thread exiting (1)
> 03/18/05 10:07:37 -316040272 Toolkit __init__.py:988 INFO Heartbeat thread exiting (1)
> 03/18/05 10:07:37 -169178192 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_28949e09_p_globus_io_handle_t result=(52, 'an I/O operation was cancelled') n=0
> 03/18/05 10:07:37 -169178192 EventClient __init__.py:988 DEBUG readCallback gets failure in result: 52 an I/O operation was cancelled
> 03/18/05 10:07:37 -151080192 EventClient __init__.py:988 DEBUG Free callback _40dd9809_p_callbackStruct
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO Method Venue.RemoveBridge called
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO streamId = 00000102b64bc71800a400360064000dac9
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO removed
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO Method DestroyBridge called
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO - Refcount zero; stopping and deleting bridge
> 03/18/05 10:07:37 -284570704 Toolkit __init__.py:988 INFO Heartbeat thread exiting (1)
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO Method Bridge.Stop called
> 03/18/05 10:07:37 -151080192 Toolkit __init__.py:988 INFO streamId = 00000102b64bc71c00a400360064000d146
> 03/18/05 10:07:37 -305550416 Toolkit __init__.py:988 INFO RunQueueThread exiting
> 03/18/05 10:07:37 -158688336 EventClient __init__.py:988 DEBUG Read Callback called arg=None handle=_f84f9d09_p_globus_io_handle_t result=(54, 'an I/O operation was cancelled') n=0
> 03/18/05 10:07:37 -158688336 EventClient __init__.py:988 DEBUG readCallback gets failure in result: 54 an I/O operation was cancelled
> 03/18/05 10:07:37 -151080192 EventClient __init__.py:988 DEBUG Free callback _80e69809_p_callbackStruct
> 03/18/05 10:07:38 -151080192 Toolkit __init__.py:988 INFO Shutdown exiting
> 03/18/05 10:07:38 -274080848 Toolkit __init__.py:988 INFO RunQueueThread exiting
> [aguser at pcdiag11 accessgrid]$ ./startVNCserver
> Xvnc version 4.0 - built Aug 27 2004 09:53:08
> Underlying X server release 60700000, The X.Org Foundation
> Wed Mar 16 15:30:57 2005
> vncext: VNC extension running!
> vncext: Listening for VNC connections on port 5908
> vncext: created VNC server for screen 0
> error opening security policy file /usr/X11R6/lib/X11/xserver/SecurityPolicy
> Could not init font path element /usr/X11R6/lib/X11/fonts/TTF/, removing from list!
> Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing from list!
