[AG-TECH] Problem with mic, rat and gentoo
Colin Perkins
csp at csperkins.org
Tue Mar 15 03:36:37 CST 2005
And if you send the device name to rat-trap at cs.ucl.ac.uk we can add it
to the hard-coded list for the next version of rat.
Colin
On 15 Mar 2005, at 04:44, Thomas D. Uram wrote:
> This is a characteristic of AC97 based cards. Rat handles some of
> them by hardcoding; others can be handled by setting the OSS_IS_AC97
> environment variable.
> export OSS_IS_AC97=1 (for sh)
> setenv OSS_IS_AC97 1 (for csh)
> Hopefully this fixes the problem.
> Tom
> Ashley Wright wrote:
>> Hi Jason,
>> This was the first thing I tried, I prefer the talk to start muted,
>> however the setting made no difference.
>> This is a strange problem. I have had a look in the AudioService
>> script (inside AudioService.zip) but cant find anything I would think
>> would make a difference.
>> Ashley
>> Jason Bell wrote:
>>> Hi Ashley
>>> Have you tried editing the audio service settings through the
>>> "manage my
>>> node" configuration tool????
>>> You have the ability to change the input and output levels as well as
>>> turning talk on and off.
>>> These setting may help as well.
>>> Cheers,
>>> Jason.
>>> Jason Bell, B.I.T.
>>> B. Info. Tech. (Honours) Student
>>> Network Engineer
>>> Information Technology Division
>>> Central Queensland University
>>> High Performance Computing Support Officer
>>> Research Assistant to the Nonlinear Intelligent Systems Research
>>> Group
>>> Faculty of Informatics & Communication
>>> E-mail : j.bell at cqu.edu.au
>>> Phone : 07 4930 9229
>>> Patience is a virtue.
>>> But if I wanted Patience,
>>> I would have become a Doctor.
>>> -----Original Message-----
>>> From: Ashley Wright [mailto:a2.wright at qut.edu.au] Sent: Tuesday, 15
>>> March 2005 12:55
>>> To: Jason Bell; 'ag-tech at mcs.anl.gov'
>>> Subject: Re: [AG-TECH] Problem with mic, rat and gentoo
>>> Hi Jason,
>>> This looks good, I have found the file and the setting
>>> "*audioInputMute:
>>> 1" However if I set this to 0, next time the Venue Client opens the
>>> RAT it is set make to 1.
>>> Also interesting, if I open RAT with the command "rat
>>> xxx.xxx.xxx.xxx/xxx" the mic setting is left unchanged (this is
>>> good), however if it is opened with the Venue Client then I still
>>> get the feedback. This is making me think the venue client is doing
>>> something I do not want it to do.
>>> Any more ideas?
>>> Ashley
>>> Jason Bell wrote:
>>>> Hi Ashley
>>>> There is a RatDefaults file in the home directory (Well there is for
>>>> fedora anyway), you might want to changes some of the settings in
>>>> that
>>>> file so that when "rat" starts up, none of your settings are
>>>> changed.
>>>> Hope this helps.
>>>> Cheers,
>>>> Jason.
>>>> Jason Bell, B.I.T.
>>>> Network Engineer
>>>> Group
>>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
>>>> On
>>>> Behalf Of Ashley Wright
>>>> Sent: Tuesday, 15 March 2005 11:59
>>>> To: ag-tech at mcs.anl.gov
>>>> Hi,
>>>> Normally in the mixer (gnome volume control), we have the mic input
>>>> muted, with the record ticked. This works. Our problem is that when
>>>> rat
>>>> is started it un-mutes the sound, so that the sound plays though
>>>> the speakers. Ticking the mute box fixes this again.
>>>> My problem is that every time rat is opened, or settings are
>>>> changed, the mic feedbacks though the speakers, and I have to tick
>>>> the mute box again.
>>>> We are running a sound blaster live. We are using OSS because ALSA
>>> gives
>>>> a distorted sound.
>>>> This does not happen on our Fedora Access Grids, only our gentoo
>>>> Access
>>>> Grid.
>>>> Anybody have any other ideas?
>>>> Ashley
>>>> Gavin W. Burris aka 86 wrote:
>>>>> Sounds like you have to adjust your mixer to not play capture back
>>>>> through. If you are not using ALSA, then I would highly recommend
>>>>> it.
>>>>> My notes, including mixer screen-grabs, here:
>>>>> http://viz.aset.psu.edu/ga5in/AccessGridNodeOperation.html#audio
>>>>> Ashley Wright wrote (on Mon, 14 Mar 2005 at 09:09):
>>>>>> Hi,
>>>>>> We have set up a single computer accessgrid using Gentoo Linux. We
>>>> have
>>>>>> used the official AG2.3 toolkit.
>>>>>> My problem is that every time a new rat is opened (changing venue
>>> etc)
>>>>>> or a setting is changed, rat unmutes the microphone and the mic
>>>>>> plays
>>>>>> directly into the speakers. This causes feedback though the mic
>>>>>> and speakers. I then need to remute the mic in the gnome volume
>>>>>> control
>>> to
>>>>>> get rid of the feedback.
>>>>>> Does anybody have any ideas of what could be causing this, and a
>>>>>> suggested fix.
>>>>>> Thanks,
>>>>>> Ashley
>>>>>> Ashley Wright
>>>>>> 3864 9264
>>>>>> HPC and Research Support Group
>>>>>> Queensland University of Technology (QUT)
