[AG-TECH] Bridge Start-up Failure Question
Thomas D. Uram
turam at mcs.anl.gov
Wed Jun 22 16:54:23 CDT 2005
John:
The problem in this case is that the path to the config file includes spaces. Try using
the config file from the current directory:
BridgeServer.py -c bridgeserver.cfg
You probably don't want to have the bridge server config file in the installation
directory anyway.
Tom
On 06/22/05 11:04, Casagrande, John wrote:
> I have attempted to install a Venue Server and Bridge Server on a
> Windows 2003 Server machine. When I start the Bridge Server I get the
> following error messages note that the first line is the command line I
> executed to start the bridge server:
> C:\Program Files\AGTk-2.3\bin>BridgeServer.py -c C:\Program
> Files\AGTk-2.3 \Program Files\AGTk-2.3\bin\bridgeserver.cfg
> Traceback (most recent call last):
> File "C:\Program Files\AGTk-2.3\bin\BridgeServer.py", line 788, in ?
> main()
> File "C:\Program Files\AGTk-2.3\bin\BridgeServer.py", line 781, in
> main
> bridgeServer.LoadConfig(configFile)
> File "C:\Program Files\AGTk-2.3\bin\BridgeServer.py", line 352, in
> LoadC
> raise InvalidConfigFile, \
> __main__.InvalidConfigFile: No BridgeServer section found in config file
> main()
> main
> LoadC
> Here is a copy of my config file:
> [BridgeServer]
> name = USCNorrisCancerCenter
> location = LosAngelesCa
> qbexec = C:\Program Files\AGTk-2.3\bin\QuickBridge.exe
> BRIDGESERVER= USCNorrisCancerCenter
> #use this port range for bridge server
> portMin = 30000
> portMax = 40000
> [https://ccweb2.norccc.usc.edu:8000/VenueServer]
> type = VenueServer
> [https://ccweb2.norccc.usc.edu:8000/Venues/default]
> type = Venue
> # optional specification of port range for bridges in this venue portMin
> = 30000 portMax = 30010
> Can someone please tell me what is invalid in my config file? I have
> tried several different combinations but all seem to fail.
> Thanks.
