[AG-TECH] Osprey 440 Cards, Matrox QID Video Card, Recommended Soundcard
Derek Piper
dcpiper at indiana.edu
Wed Jun 22 08:22:16 CDT 2005
Richard Naylor wrote:
> At 01:58 PM 6/20/2005 +0800, Peter DeSantis wrote:
>> Didnt know there was a 4 channel osprey, gonna check that one out myself
> I have an Osprey 440 - its one of the first 20 pre production units and
> is loaded with beta drivers. Previously we have used 4x Osprey 100 and
> lately Spectra-8 cards for video capture in AG nodes running under
> windows. The Spectra 8 is a nice card, but does have an annoying habit
> of asking which port goes where every time you go into a venue.
Which suggests that the Osprey doesn't suffer from that problem? How
does it get around it? Is the driver just smart enough that they grab
whatever source is free?
*snip*
> My next test was to run it as an Access Grid node. Sadly this wasn't so
> great. The first input loaded as a "video Producer" like a dream. The
> second one produced errors "C++ error" and complained that you can't
> access the same device twice. Third and fourth VideoProducer loads did
> the same thing. However, at least two of them then worked !! Of course
> the next time I tried it - only one input worked and only one has worked
> since then.
Ah, apparently not so good after all...
On your VIC windows, try the 'release' and 'configure on transmit' for
the different ones. The MDM driver SHOULD ask for what input to capture
from, just like every other windows capture card/device I've seen.
I think you're going to get that same problem with any multiple input or
even multiple single card under windows. It's not the Spectra8, it's VIC
and Windows. VIC doesn't know what to pull from (I mentioned it in a
previous post). It's just a fact of life with the current VIC under
Windows. Until it stores more info in its config as to what input on the
'MDM capture' driver it's using, that problem will remain.
Derek
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
