[AG-TECH] starting RAT and VIC manually
Derek Piper
dcpiper at indiana.edu
Fri Jun 17 08:31:27 CDT 2005
The VIC and RAT executables are located in their service directories
for the user running the AG. So, for Windows they will be in the
AudioService and VideoService (or VideoProducer etc.) directories under
(one path):
C:\Documents and Settings\<username>\Application
Data\AccessGrid\local_services\
You can run them from there or copy them out. If you copy them, make
sure you get all of RAT's executables in the same directory or it will
not work.
Derek
chanhm at ihpc.a-star.edu.sg wrote:
> Hi,
> I am using a Windows PIG node.
> Previously, in AG 2.2, I was able to start RAT manually and connect directly to a bridge, by running the rat.exe in the bin directory. However, this executable seems to be missing in the new AG 2.3 bin directory.
> Is it still possible to run RAT manually in AG 2.3 without starting the AG Venue Client? Thanks.
> Regards,
> Hoong Maeng CHAN
> Institute of High Performance Computing
> www.ihpc.a-star.edu.sg
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
