[AG-TECH] Error trying to conect to the VenueServer.
Natalia Costas Lago
natalia at cesga.es
Tue Jun 14 06:28:16 CDT 2005
The last couple of weeks I've been getting an error trying to connect to University of Vigo's server. I needed a second and even third try for the connection to be successful (from clients on different machines). I didnt ask for the server to be restarted, because the development team might be interested in this particular error. I copied from the Venue Client log.
I will ask some people from the University of Vigo to check if they get the same error.
06/14/05 13:07:44 1236 VenueClient venueclient.py:669 ERROR SOAP fault occurred
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 347, in __call
config = self.config)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 187, in call
r.endheaders()
File "C:\Python23\lib\httplib.py", line 712, in endheaders
self._send_output()
File "C:\Python23\lib\httplib.py", line 597, in _send_output
self.send(msg)
File "C:\Python23\lib\httplib.py", line 564, in send
self.connect()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1093, in connect
self.sock.connect(self.host, self.port, self.io_attr)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 671, in connect
raise ex
GSITCPSocketException: an authentication operation failed
06/14/05 13:07:44 1236 VenueClient venueclient.py:851 ERROR EnterVenue: globus tcp exception: ('an authentication operation failed',)
06/14/05 13:07:45 1236 VenueClient venueclient.py:258 ERROR __CheckForValideClock: failed; time is okay (offset=1
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 834, in EnterVenue
self.__EnterVenue(URL)
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 703, in __EnterVenue
(venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3331, in Enter
(r1, r2, r3) = self.proxy.Enter(profile)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
self.__hd, self.__ma)
r.endheaders()
self._send_output()
self.send(msg)
self.connect()
raise ex
06/14/05 13:07:45 1236 VenueClient venueclientui.py:1959 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agserver.uvigo.es:8000/Venues/default
06/14/05 13:07:45 1236 VenueClient venueclientui.py:1970 DEBUG Authorization failure connecting to server.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050614/9f6aaa5b/attachment.htm>
